3.50-7 tires
bucktail
Jun 13, 2016
1,255
190
MN
I've got a late 70's-early 80's Honda FR500 tiller with the factory tires on it. Those tires are getting a little long in the tooth and are dry rotting. I've found wheelbarrow tires in that size, but nothing with substantial lugs on it. I'd like R1's, but a snowblower tire should work fine too. Partstree is out, and alibaba has a minimum order quantity of 30.
6,378
I did a quick search and found OEM part #42751-723-751 - HONDA POWER EQUIPMENT Parts
Wow....VERY proud of them at $75 or $85!
I agree 100% R1 is way to go, but I'm drawing a blank on another common option besides wheelbarrow....
bucktail
Jun 13, 2016
1,255
190
MN
They seem to be more common abroad as alibaba and global sourcing have them, but their minimum order quantities are off putting. I may end up measuring the shaft and seeing if I can get a similarly sized 6" rim and tire combo from a junk tiller or snow blower. I'd rather not because it has cast iron wheel weights that wouldn't fit if I went that route.
bucktail
Jun 13, 2016
1,255
190
MN
Partstree got some in 95 per tire
bucktail
Jun 13, 2016
1,255
190
MN
Best option yet, but they aren't R1's.
Anyone ever put in a boot that lined the whole tire? I don't put enough air in them to register on the gage. The side walls used to be stiff enough to support the tiller with no air pressure. Not sure I could get them off and on again in one piece. What would you use for boot material? An old inner tube?
I'll probably see if I can find a set of snowblower wheels with 6" rims on them that fit my axles. I'll lose the wheel weights if I go that route, but the frame has a square section in front that I can put a square shaft into and hang some weight from that. Some of the snowblower tires have some nice big lugs on them that would probably stand in just fine for R1's.
