2846A discharge chute rotate
filipows
GR2120
Jan 13, 2025
Eastern Washington
I bought a used 2846A back in the spring. It was in the barn until recently.
I brought it out to do maintenance and mount on GR2120. Prior to, I took the GR out to the barn, plugged in the electric discharge rotate connector. It worked, I was happy.
After cleanup, maintenance and install I plugged in the connector and tried it out again. went left, back to the right and then it just quit! Checked what I could and found no problems. I have a replacement motor unit on the way.
BUT If I had the parts would switch it over to manual crank for rotation. I can't imagine it would be difficult. Justt need parts or part numbers.
Suggestion on where to shop?
imarobot
5740HSTC-3, FDR2584 Finish Mower, BH92 Backhoe, L2195A Snowblower, LA854 FEL, +
Apr 18, 2025
263
159
NH
Don't know what a 2846A is, but did you check for a blown fuse in whatever circuit the electric discharge?
Orangeglow
2015 BX2370
Jun 19, 2014
359
181
Prescott, Ontario
Get your test light out and check to make sure you have battery and ground at the control when you are trying to activate the chute. Use a test lamp with a very sharp pointed tip to pierce thru the insulation. That should be a very easy thing to trouble shoot to find where your problem is. Please let us know what you find.
filipows
GR2120
Jan 13, 2025
Eastern Washington
No real good news on chute rotator. Just more questions.
In the beginning, as described tested chute rotation after snowblower was installed. Went one direction then the other once and STOPPED. No obvious reason. FWIW included picture of wiring "under the hood" Checked there no problems found
Cleaned contacts and tried again, no change. Used test light in photo, with ignition on, made contact with the cable connector light worked with switch in both directions. If the light bulb worked why not the motor?
I found a used motor, plugged it in same thing NOTHING. Put it aside to do other things. Today I connected a ground wire from chassis to motor casting.
Shocked the used motor rotates one direction, not the other. Original motor same situation, nothing happens.
Thinking problem might be in the toggle switch. Will check into that. But still the question is why the test light works both direction but not the motor???
Have you eliminated the controls as the source of the problem? that's where I'm going next. Any experience to share?
Dustball
2016 B2650HSDC
Sep 15, 2023
441
302
Hudson, WI
Is the polarity being switched when you try changing directions? A light bulb doesn't care about polarity but a DC motor does.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,796
2,187
Near Lancaster, PA, USA
What Dustball said. Test polarity. You can do this with your light. The colors were used for ID and probably won't match what you have. Assuming you have two wires that connect the chute.
First, connect the light between the wires illustrated in red and black coming from the switch to the motor. Do this with both switch positions. It should light both times.
Next, test between the red and a known ground as in the picture. The light should only light when the switch is in one position.
Next, connect the light between the black and the ground. It should only light when the switch is in the opposite position.
filipows
GR2120
Jan 13, 2025
Eastern Washington
Chim
Thanks very much that makes sense. Very well done and clear
