2022 SVL75-3 default pin
MMK68
2022 Kubota L3560/ 2000 SVL75
Oct 12, 2023
17
Hi.
I purchased a brand new SVL75–3 at the auction. Unfortunately, I was not provided a four digit pin to start the machine. Is there a default pin? I tried 1111 and it does not work. Is there a way to reset this four digit pin? Thank you in advance.
woodman55
L6060HSTC, RTV 1100
May 15, 2022
937
733
canada
Just a guess, Try the last four digits of you serial #, or the last four backwards. look in the owners manual and see what it states, or call your dealer.
whitetiger
Nov 20, 2011
2,939
1,398
Kansas City, KS
Hi.
PIN 1111 is the default until it is changed. Try asking the seller for the new PIN.
If have no PIN, you must take the serial number and proof of ownership to a dealer who can log into the Kubota Link Dealer Portal and retrieve a master code. With the code and instructions, you can log in and retrieve the PIN which you can use or change to your own.
MMK68
Oct 12, 2023
17
Thank you. I tried that, but it did not work either.
MMK68
Oct 12, 2023
17
Thank you very much. I’ll contact a nearby dealer.
