2020 MX5200 HST LA1065 Loader - Power Beyond
djm
MX5200HST
Jul 4, 2026
Owasso OK
I am adding a Woods backhoe. I have third function and
Summit Hydraulics 4spool remotes on the rear so I have the power beyond hydraulic circuit at the back that connects to the loader valve and hydraulic block below the loader valve.
NonKubota Woods dealer told me that I needed to purchase a Woods power beyond kit,$650, that would connect to a better location than the loader valve and hydraulic block.
Does anyone know if there is another power beyond location on an MX5200 hst and a part number for a kit to use it.
7,262
No "kit" needed. All you need to do is put a quick coupler on the PB return on the Summit manifold and a matching coupler on the backhoe supply hoses
To hook up the backhoe you disconnect the PB coupler on the manifold and connect the male and female halves to the matching halves on the backhoe hoses. Just make sure you get the flow setup in the correct direction. The PB outlet on the manifold connects to the supply hose on the hoe and the return hose on the hoe connects to the PB return hose on the tractor. This is exactly how Kubota plumbs their hoes.
EZ-PZ and more like $40 than $650 :devilish:
