SOLD
2018 X390, 22hp, Gas, Twin cylinder
-Factory warranty is good until May 2022 or 300hrs!!
-Purchased new from Deer Country Farm and Lawn May 2018
-Hours: 96
-Only been used to cut lawn and pull a small cart with leaves. Never seen snow etc.
-Always kept inside!
-54" Accel Deep Cut W/Factory Mulching kit + Mulch control
-Electric on dash mulch on/off control (great for tall grass areas to open the side discharge up then close again around the house right on the dash!)
-Hydro steering (no vibrations or bumps etc. felt through the steering wheel like you get with a manual steering tractor)
-Hydro deck lift (Also lifts any front mounted implements like a plow or snow blower)
-Hydrostatic drive with forward and reverse foot pedal operation. Very easy to drive and maneuver!
-Cruise control
-Hydro fluid and filter changed at 50hr as per the manual.
-Other info can be found on the John Deere website. Same as the 2019 X390 models.
Comes with:
-Side discharge deflector (I removed it since I use the mulching kit but can easily be installed again)
-Manual mulch control lever (replaces electric actuator if you ever want to remove that and return it back to manual control on the deck)
-Original owners manuals for the tractor and deck
-Spare key
-Delivery can be arranged as well if required.
Please let me know if you want to take a look or would like more pictures etc.
Located in the Kutztown/Fleetwood, PA area Zip: 19522
Never had an issue, Selling it due to acquiring more property and a compact tractor.
-Hours: 96
-Cruise control
Comes with:
-Spare key
