2016 BX 1870 Hydraulic filter exploding
armylifer
Mar 26, 2013
2,310
1,069
Thurston County, WA
Is it possible that you put the filter on and reversed the inlet and outlet of the filter? I don't know if the filter is a one way filter but some are.
11,753
This is the filter that the OP changed. Part # hhk20-36994. Is the o-ring from the original filter stuck on the transmission? The OP seems to know his/her way around the tractor so it seems unlikely but you never know.
10,815
Oh I know my way around equipment, and I've had the double gasket bite me in the back side! 🤬😭
It normally will just leak when that happens. :oops::confused:
11,753
I have an idea in my head as to what "filter exploding" looks like, but reality might be different than perception. It's often difficult to diagnose problems from afar but it will be interesting to see how this is resolved.
7,063
It is building enough pressure at the filter to completely separate it
You forced me to read the WSM for you.
The back pressure on the HST filter is limited by reliefs inside the HST transmission (@ruger1980).
Something is obstructing that path or the HST suddenly went belly up for no reason. Since all you did was change the filter I would be looking real hard at the filter mounting base on the transmission.
11,753
He also changed the fluid, so if a piece of aluminum foil from the top of the oil container got into the transmission could it cause a major issue such as this?
ruger1980
L4310 w/La682, L225
Oct 25, 2020
569
247
CNY
Anything put into the sump would have to go through the strainer, the hyd. pump, the priority valve, the steering controller, the filter and then into the HST to the charge relief.
ruger1980
L4310 w/La682, L225
Oct 25, 2020
569
247
CNY
Is the filter separating the canister from the base and leaking at the seam or is it deforming the base and leaking at the gasket? If at the gasket is it possible that the threaded insert has been damaged and the filter gasket is not square with the base as has been mentioned?
If the filter is indeed separating at the seams I would remove the Charge relief as @NIW showed and inspect for blockage. You could even leave the spring and poppet out as a test. Beware that you will likely get oil from the sump when you remove the poppet so you will need a drain pan to catch what drains.
Mark_BX25D
Bx25D
Jul 19, 2020
2,100
1,606
This.
A good description of "filter exploded" would be very useful. One man's "filter exploding" might be another man's "leaks a lot at the base".
11,753
Very commonly a piece of silicone gasket material gets dislodged and goes into the relife port.
Nice! A plausible reason for the high pressure and a plausible source of the contamination. (y) Good thread, kind of like an Agatha Christie murder mystery. :ROFLMAO:
1870bx
Bx1870
Feb 21, 2026
15
Ok I havent had time to check the other relief yet hoping to do that one evening this week and I will get back with you.
1870bx
Bx1870
Feb 21, 2026
15
This.
The kubota filter expanded and blew the seal out, and took the base from concave to convex. The Donaldson filter separated itself from its base and shot off of the tractor.
7,063
The HST circuit cannot handle anything remotely close to the implement circuit. That is why the implement relief(s) have no bearing on that filter. All of this can be easily gleaned from the hydraulic diagram in the WSM.
