2014 ZG327 Fuel Tanks Problem
JRowland
2014 Kubota ZG327
Apr 24, 2016
Dublin, GA
I have a 2014 ZG327 60" Side Discharge that I bought used last month with 60 hours on it. I filled both gas tanks before using it the first time. The fuel gauge (which shows the level of the left tank) is showing near empty, but the right hand tank is still full. According to the manual, the mower is supposed to draw down both tanks evenly. Any ideas? Thanks!
whitetiger
Nov 20, 2011
2,941
1,399
Kansas City, KS
Either your primary RH tank filter, vent or check in the fuel supply line Tee is plugged.
6,596
There is 2 filters one on each tank.
Have you checked / replaced those?
JRowland
2014 Kubota ZG327
Apr 24, 2016
Dublin, GA
Haven't checked anything yet, but I will check filters and vent. I filled the left hand tank up to below the filler neck and siphoned some gas out of the right hand tank because it was above the filler neck. After I siphoned the gas off it filled back up above the neck.
