2012 M135GX No Remote Hydraulics
iRaven
M135GX
May 8, 2023
Purchased a M135GX with 2000 hours. Went to use the hydraulics and can hear the tractor try to do something but nothing happens. Pulling a 30' roller, only one set of hydraulics lines, very simple. Tried all 4 remotes and nothing.
Has loader with 3rd function, and that works.
3pt works no problem up or down.
PTO works no problems.
The tractor was performing a DPF burn, but didn't think that would matter.
Scratching my head on this one.
Thanks.
4,668
4 remotes = 8 outlets
2 remotes = 4 outlets
Which do yoy have and is your roller hydraulic connection using two hoses?
iRaven
M135GX
May 8, 2023
I've tried all of them. Blue, Green, the other two are both black. They are connected correctly, using only one set of remotes. Currently in Blue.
Lines are not popped out.
I've check fluid level, that's ok.
I've read some issues where you have to full throttle at the start for the hydraulic system to prime.
Was going to roll 30 acres before planting corn, but going ahead without doing it.
iRaven
M135GX
May 8, 2023
Figured it out. The previous owner flipped the cables between the cab levels to the valves from blue to green and the blacks were flipped.
After getting a second set of eyes and moving the levels we figured it out. But how frustrating that can be. Ready to go but just doesn't work.
