I have a L4600 with 750 hrs on it. It started to white smoke at cold start, a slight ping when cold and when warmed up it lopes at idle. I removed all the injectors and the injection shop said the pop pressure was low on all of them. They replace the tips cleaned them up and I reinstalled them. White smoke at start up is gone, slight ping when cold is gone but still have loping at idle when warm. If i crack the fuel injector lines while loping, the #1 cylinder doesn't seem to slow the engine down. if I rev the engine up to over 1100 rpms the engine smooths out and cracking the #1 fuel line slows the engine down. Using a AI chat sight they say I have carbon build up in my prechamber of #1 and running is under high speed and power will clean this up. Has anyone else had this issue?
