2012 Kubota L3800 repair manual
Jblac197
L3800, bush hog, tiller snowblower
Aug 21, 2018
73
Hibbing
Anybody know where I can find a repair/parts manual for a 2012 Kubota L3800? I want an actual book, found the ones I can download but much rather have a paper copy.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
9,254
Get it from a Kubota dealer.
Parts manual, P/N 97898-25000 $31.12
WSM (aka Service manual), P/N 9Y111-05201 $109.13
And FYI: These will just be the papers, you'll need to provide your own three ring binder to put them in.
Jim L.
870
171
The parts manual is good for getting a mental picture of what goes where.
Be aware that the part numbers in the paper manual may change, even multiple times, as vendors or improvements happen. So if you need to order a part, check for the latest part number.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,047
Williamstown Ontario Canada
Since you are going to have to bind your own pages from Kubota, get a pdf, print it or have it printed and bound..
My very old paper manuals for Nuffields, eventually fall apart. Recently the expensive paper WSM from GM for my car, split down the middle of the binding.
In spite of what you pay, often the paper is low quality.
Another improvement offered by the electronic version, again using the L 2800, 3400 wsm:
The wiring diagram for the HST model is not complete. For example one wire going to starter. You have to refer back to the manual transmission wiring diagram to get a lot of the important details.
Electronically, you could have each wiring diagram on a split screen. with a paper manual you have to keep turning back pages.
This is the wiring for the manual transmission tractor
Dave
Fordtech86
L3200
Aug 7, 2018
4,966
5,916
Pineville,LA
Dave
You wore the GM manual out?:eek: You are working on that thing way too much:p.....just messing with you
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,257
1,047
Actually, it is a Toyota in disguise. A Pontiac Vibe built in the California plant along with Toyota Matrix's. The same plant were Tesla's are now built. Nummi was the plant name.
Dave
