Hi,
First to introduce myself. My name is Justin Rose. I'm from a small central WI town, and run a campground there. I also serve with the WI Army National Guard as a Fire Support Officer.
Problem: I fired up the tractor, and let it run a idle for about 10 min prior to moving. I drove about a 1/2 mile, and stopped to do something, and noticed hydraulic fluid pouring from around the oil pan. It looks to be coming from the cover (I assume for the front driveshaft). I see no cracks. I don't hear any unusual noises. It moved fine without hesitation. The oil was clean ,and clear as I just changed it about 30 hrs ago. It was about 15F outside, and had been -20F during the night. I retraced my steps, and the leaking appears to have started at the location I started the tractor. The tractor has 700 hrs on it.
Any helpful advice would be most appreciated.
Thank You
Thank You
