2002 Kubota BX2200D with 60" Mid-mount Mower Deck
grandpa_e
MX5400, ZD1211, BX23S, BX220
May 13, 2026
Louisiana
2002 Kubota BX200D, 4 wheel drive tractor with RCK60-22BX 60" mid-mount mower deck . Tractor has 1790 hours, but I am still using it so that may go up. Engine doesn't burn oil, doesn't smoke, starts easily and runs great. All hydraulic hoses replaced at 1000 hours. Steering hydraulic cylinder replaced at 1400 hours. Rear axle seals replaced at 1500 hours. Front axle seals replaced at 1650 hours. Generator was replaced at 1780 hours. Mower deck has had all spindles, bearings, seals, belt, etc. replaced at about 1200 hours. Everything works like it should and has been mechanically well maintained. All maintenance has been done at kubota recommended intervals using kubota fluids and filters. I have some spare parts that will go with the tractor as well, including a complete set of wheels and tires, the old spindle housings, spindles, deck hanger parts, tensioner assembly, etc. from the mower deck, a new accessory belt, a new water pump and gasket set. It doesn't need it, but I bought the water pump for future replacement. See pictures for included parts. ROPS was removed, but will go with the tractor. Very fuel efficient , I can mow a little over 20 acres on less than 6 gallons of diesel. It isn't pretty, but it's a workhorse small tractor and mower. Mows great! Located in Southwest Louisiana. Asking $6,500. 1533.jpg 1524-r.jpg
grandpa_e
May 13, 2026
Louisiana
For some reason I can't get pics uploaded. I keep getting an error. I'll try again tonight...
3,394
I think you have to have made something like five posts before you can post pictures…
I believe I’ve seen people in the past post something like “post # 3”…”post # 4” then after the fifth post, post their pictures. After that you’re good to go because you passed the five post requirement.
I’m not sure if the number is actually five but I believe it is. If it isn’t it’s very close…
grandpa_e
May 13, 2026
Louisiana
I was able to upload one picture, but all others are a no-go. Not sure what the problem is, but if anyone wants to see the others, I can email them.
grandpa_e
May 13, 2026
Louisiana
Got it. Apparently the files were too large. Reduced the size of the images and now they work... FInally...
