1997 B1550 Steering play
Juiced06GTO
2016 B2601
Nov 26, 2014
79
Sutton, MA
Hey guys I am new to the forum, I just picked up a new to me B1550 with 1200 hours on it. It has a few issues I need to take care of on it. The major one is the free play in the steering. I have done a search and found a bunch of posts on the issue. I had a few questions that weren't answered.
The rebuild procedure in the articles section, is that for a PS box or manual box? Also, I don't have any fluid leaking out the top of my column, so I am guessing the lower seal is still ok, but I do have about a 1/4 turn worth of play in the wheel. I am guessing that just replacing the bushing and seal at the top of the column is not going to get rid of this play, I am guessing I need to rebuild the entire box?
Thanks for any and all help!
Anthony
kuboman
721
There is an adjustment that you can do which may take out some of the play. A lock nut and set screw on the side of the box. Have you checked all the linkages and tie rods to make sure the play is not there?
Juiced06GTO
2016 B2601
Nov 26, 2014
79
Sutton, MA
I can move the steering wheel about a 1/4 turn before I can see it start to move the drag link on the steering box. There are a bunch of tie rod ends that need to be replaced as well. I am hoping they are all adding up to make the play as bad as it is.
8,829
Yea I would try the adjustment on the side of the box first.
