1976 Kubota L225DT Main Ignition Switch
Pugsley
1976 Kubota L225DT
Dec 29, 2018
Nashville, Indiana
I could use some help or advice…
The main ignition switch went out.
Cannot find a new or aftermarket.
Any suggestions on where to find one or another that will work same as original..???
it’s a great tractor but I am a lifetime welder and if I can’t weld it, everything is a challenging mystery…..
Thanks..!
Roadworthy
L2501 HST
Aug 17, 2019
1,647
529
Benton City, WA
You should probably get some help from someone who knows electrical stuff. Any automotive ignition switch would probably work but you'd need to add a separate switch for the glow plugs. I suspect any generic tractor switch would work but you'd have to sort out which wire goes where. If you want an oem switch try the Kubota dealer. Beyond that you may connect with an after market one on Amazon or eBay.
