1952 Massey Harris Pony - Value Question
bird dogger
Feb 24, 2019
1,808
1,782
North Dakota
From the looks of the tires (if they're still the originals) the tractor certainly hasn't seen much abuse. That will be a cute little parade tractor all dolled up. Or even used and kept in its original work clothes as is!! If mice haven't found a way into it, it probably won't take too much effort to get it running again. Most people I know would be proud to have that in their tractor lineup!!!
Outnumbered
Kubota L3901, FEL, BB1260, RCF2060, FDR2572, Forks, 55" Grapple, 5' Tiller .....
Oct 26, 2019
269
488
Moseley, VA
Well I have decided to dig in a bit and at least get it running. I may decide to go as far as keeping it for a little garden tractor if it's not too involved. Drug it out a bit and started a little dismantling. I will drag it over to the house in the next week or so so I have access to water, compressed air and an array of tools to see where it takes me.
5,536
The nice thing about machines like/similar to yours is that they are/were pretty simple to work on.
I have a friend that has an old Ford that I have gotten started a few times after sitting for years and years….
One of the nice things is that the Tractor Supply near us keeps a pretty decent selection of “spare parts” in stock. Lots of carb and ignition parts available…..(at least for older Fords anyhow…… (y) )
Even had a 6 volt battery in stock one time……..
Outnumbered
Oct 26, 2019
269
488
Moseley, VA
It is an old 6 volt and will need a battery. Interesting thing is that it has the hand crank option and I found the old hand crank for it in the corner of the barn. :) That will be useful for turning over the engine once I add some old Marvel Mystery Oil to the cylinders.
bird dogger
Feb 24, 2019
1,808
1,782
North Dakota
Here's hoping you find it much easier to get it running than anyone would expect!! Like @RWS mentioned, there just isn't a whole lot of complicated systems on these ol' tractors. If you can get it to turn over..... it will run!! Fingers crossed....!!!
SDT
Apr 15, 2018
3,700
1,420
Nearly all vintage tractors of the era had manual starting means.
Be advised that long idled flathead engines are notorious for sticking due to rust in the valve guides.
Take your time and don't force things.
whitetiger
Nov 20, 2011
3,778
2,183
Kansas City, KS
As that tractor sits right now in the picture you posted $200-500 at best. If anyone thinks $2-3000 then, I have a backyard full of tractors they can buy. Non running, unrestored, not extremely rare antique tractors don’t have a lot of value. Everyone thinks they do, but buyers don’t.
If it were in this area, I would give $2000. for it in a heartbeat!!
Outnumbered
Oct 26, 2019
269
488
Moseley, VA
Update, I lubed it and was able to easily turn over the engine with the hand crank. I have cleaned the tank, fuel bowl and carburetor and am now waiting for new gaskets for the carburetor as once I cleaned up that I have some bad fuel leaks. I also put a new battery in and it is turning over fine just need to address a no spark which I believe is due to the points as they are in rough shape so I will order a set as well. Hopefully after these last two items and can get it started and moving under its own power. WooHooo
Reactions: 7 users
SDT
Apr 15, 2018
3,700
1,420
Sounds like you are well along the way.
I expect that you will be able to get it running.
It will sell much better once you do, or you may decide to keep it. Collecting antique tractors can be addictive.
7,697
They don't have to be antique!
Outnumbered
Oct 26, 2019
269
488
Moseley, VA
It's alive!!! Man, once I reworked the carb, put new points and a distributor the darn thing fired right up. Purrs like a little kitten. I took it for a little spin and everything works as it should. I could not be happier. I have about $160 in parts for the battery, distributor cap and points. Money well spent to see if it would run again. Not bad for a 74 year old tractor. :)
airbiscuit
New Holland T2310, New Holland TC21D, Kubota l3010 GST, Farmall H
Mar 18, 2021
422
482
NW WI
Time to clean and paint
airbiscuit
Mar 18, 2021
422
482
NW WI
Actually, I kind of like the patina
WI_Hedgehog
Apr 24, 2024
1,130
1,646
Milwaukee, Wisconsin, U.S.A.
Funny how A.I. (fuzzy logic) turned the Exide battery into "Japanese Joe" brand.
Nice tractor either way.
But you've a newer "FOR" tractor too... Decisions decisions.... :ROFLMAO:
