Wife's uncle's Ford 8N apparently puked a bunch of oil out the breather & dip stick tube. Had been running fine, after bush hogging he pulled it into the pole barn where it puked. I had no time to look it over when I was there, but was wondering if anyone has seen or heard of this before, just to give him a starting point.
If I remember correctly, the hydraulic pump in these is back in the rear housing behind the tranny, so it doesn't seem likely that it is a hydraulic leak bleeding into the crankcase.
That would seem to leave only coolant or fuel as the culprit.
Opinions?
Opinions?
