NEPA Guy
B2650HSDC, Spacers, FEL, BH, Snowblower, Snowplow, PBar, Forks
The B2650 is rated to run conventional 15w40 for the summer and 10w30 in the winter.
I picked up the Shell rotella 15w40 synthetic blend to do an oil change today.
I see Shell makes a 5w40 full synthetic as well as Mobil 1.
Can I safely use the 5w40? Wouldnt it be better being full synthetic and able to handle more heat?
The weight is still the same and if the 5W is just the lowest temperature range it can handle, wouldn't I also be able to use the 5w40 instead of the 10w30 in the winter.
Thoughts?
Thoughts?
