*1 The initial 50 hours should not be a replacement (changing) cycle?
LukyNumbrKevin
2018 BX23s (TLB w/ a mower deck)
May 17, 2018
42
CT, USA
Ok so I am at 50 hours with my BX23s and I am a bit confused by the conflicting notes at the end of the "Service Interval" table in the manual.
I notice that for the first three items (Engine Oil, Engine Oil Filter, Transmission Oil Filter) There is a ***9678; which indicates: "You must perform the jobs indicated by ***9678; after the first 50 hours of operation." However in the notes there is "*1 The initial 50 hours should not be a replacement (changing) cycle?"
So which is it? Do I have to perform these tasks or not. This is a bit confusing. What is a replacement cycle and what is not? Would someone mind ELI5?
Creature Meadow
Sep 19, 2016
1,064
135
Central North Carolina
From my reading at 50 hrs you change oil and filter and "just" the hyro filter(s).
Not necessary to change the hydro fluid at the 50 hr service.
Many here have noted at the 50hr mark the magnet on the hydro filter has metal pieces stuck to it so glad they changed it.
2,600
There have been and may always be some "typos" or information that contradicts in the same manual for the same machine that varies over the model or year of machine.
The real question boils down to the tranny/hst oil......... change or not.
YOU should change ALL filters/clean screens.....and engine oil - but changing the hydraulic/hst oil is the one that some books say ...50 hours - some say 200 hours.
Like Creature said - sometimes you see some stuff on the screen/filter that make you say "mmmmmmmmmmm - that aint good!"
The first change is probably the most important change in the life of your engine/hst - so throw caution to the wind........change it!;)
3,520
Kevmo,,, that first 50 hours washes most all the little things out of where ever they sneak in to ,,soo yeah change engine oil and filter thats a no brainer, change the hydro filter, again no brainer,, there is a filter screen that should be cleaned as well,, and if you have a quick hand you wont lose to much hydro oil. You might find a bunch of stuff in the screen,, which means its doing its job!! and when you get to your next change everything change the hydro to SUDT, will cost a bit more but, in MHO you will see a change in your machine, the whine will go almost away... Just do it one step at a time learn your machine and suddenly it aint rocket science no more :D
5,600
This is an often debated topic.
I’m in the minority with changing all fluids at 50 hours. Given the chance again.... I would do the same.....
You spent almost $20,000 for your BX23S. Round numbers, 3.5 gallons of SUDT2 is $80, and you probably won’t change again for a couple/few years.
I know I have NEVER heard of a mechanical/engine problem due to changing oil or fluid too often.
Is the $80 worth it?
Only you can answer that question.....
JackJ
BX1870-1
Mar 14, 2016
264
9
Indiana
The way I read it: the 50 hour mark doesn’t reset the clock for the subsequent service. E.g., if the interval is 200 hours for engine oil and filter, you do the first change at 50 hours, and the second at 200, not 250 hours.
RickCf
L4701, 5ft Land Pride Rotary Cutter , 5ft Land Pride Tiller, Misc. other imp.
Jun 7, 2018
Hernando, MS
Ditto with what JackJ said. The 50 hour maintenance items do not effect the downstream compliance times.
100 td
Aug 29, 2015
1,776
9
38
ɹǝpunuʍop
If you can establish that your transmission was given a factory fill (or dealer fill) of SUDT2 then there is no need to change fluid. Why, it's not an engine, contaminants aren't being continually introduced into the oil. It has filters and/or screen to collect wear-in particles, the oil isn't breaking down in such a short space of time. But like any oil thread, everybody has a different opinion! YMMV.
LukyNumbrKevin
May 17, 2018
42
CT, USA
Thanks for all the advice everyone. I completed my 50 Hour service on Sunday and opted to replace filters and leave the current SUDT2 in my machine after inspecting the filters and finding 0 metallic particles.
I spoke with the service guys at the shop and they indicated that changing the SUDT2 at 50 hours in not necessary at all and I have nothing to worry about.
I then took her out back to continue clearing some areas of my property and ran over hidden boards with nails still in them puncturing my front left tire in 2 places. Previous owner decided that leaving garbage/trash in the woods was fine since no-one would see it. I dont understand how peoples minds work sometimes. Maybe its because I have grown up on construction site but proper disposal of demo'ed materials is key to safety, ahhh next time.
Thanks again!
2,600
Question.....
how did you pull the screen out.....clean it and lose very little of the fluid?:D:)
LukyNumbrKevin
May 17, 2018
42
CT, USA
85Hokie, are you talking about the Transmission Strainer or the Transmission Filter.
Oh I lost a bit of Transmission Fluid when I changed out the Transmission Filter, but quick hands an back-pressure prevent it from being more than 1L.
The strainer it doesn't say to clean until the 400 hour mark, should I be checking and cleaning that as well at the 50 hour mark?
skypros
BX23s
Jul 2, 2018
67
12
Bend, OR
So if we don't know what hydraulic fluid is in our machines..... Is it ok to use SUPER UDT2 or Standard UDT to top off?
