3 point hitch installed right?
Jrivas13
12
Ct
Hi, when I bought this b1600 it did not come with a 3pt hitch setup. I ended up finding a complete cat 1 kit. Does everything look like I installed everything right? And is this style complicated to hook up? Whenever I try to spread the lower arms apart to attach my counter weight barrel I have to loosen those stabilizer bars then tighten them back in to get on pins...kinda of a a hassle.
3,529
Do you mean the turn buckles on the sides? It looks like the set up is ok to me. but as far as I know there has got to be some side to side slack in them so the arms can move freely, it shouldnt be so tight that you cant move them.. just MHO you understand
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
It looks like everthing is as it should be, but I think thats a cat 0 3pth and not a cat 1. A cat 1 the arms a little longer and spread wider.
Jrivas13
12
Ct
What would the difference be between 0 and 1? I was told be the company selling the kits it was a 1.
B7100
B7100,B7100 with Backhoe and FEL, Goldoni Quad 20
Feb 11, 2010
422
Wales
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Heres a few pictures of my Cat 1 3pth on the back of my B6100
[/IMG]
[/IMG]
[/IMG]
davidbham
BX2670 w RCK60B mmm and LA243A fel, Kodiak 48" bush hog, 48" box blade
Jan 18, 2011
15
Whitesburg, TN
I don't know if it matters, but you'll notice you have the turnbuckles installed on the outside of the lower lift arms. The factory set up is to have the turnbuckles on the inside, as in Eric's picture.
B7100
Feb 11, 2010
422
Wales
On Erics factory setup the lift arms are straight,the after market version has them cranked so the turn buckles will only fit where the op has them.
dave
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Im honestly not sure if mine are supposed to be inside or outside, kinda wish they were on the outside. It would be nice and easier to tighten them up.
B7100
Feb 11, 2010
422
Wales
Inside is correct,when the arms are fitted to an implement they are spread out towards the tire so the turnbuckle on the inside forms a bracing triangle to stop the implement swinging from side to side.
From your picture Eric,it doesn't look like your turnbuckle jam nuts see a lot of use?:D
dave
Eric McCarthy
Kubota B6100E
Dec 21, 2009
5,223
Richmond Va
Inside must be a B series thing. My dads L275 has his turn buckles on the outside, much nicer to tighten them. And no I dont use the jam nuts, the turn buckles stay put pretty well without them.
B7100
Feb 11, 2010
422
Wales
The threads on my turnbuckles have copper slip on them so they adjust easier,the downside to this is they loosen off over rough ground so the jam nut have to be well tightened.
RDR
M5400,B6100E,K008,L175,TG1860Diesel,JD355D,3)Leyland 154D's,YM2000,IH1466
Oct 13, 2009
147
Danevang, Tx.
It looks to me like your sway chains are tightened in almost all of the way. I don't understand why you have to loosen them unless the pins are turned in on what you are attaching. I like the chains on the outside. My B6100E is the only tractor (B6100 to me us almost a tractor) that has the chains on the inside. I have to loosen the chains to hook up and then tighten them.
It looks like you need to move the lift links in and attach them where the stabilizer chains are and move the chain bolts to where the lift links are attached. It will lessen your lifting weight but give you more height when lifting.
Gardener Bob
BX25; Land Pride Tiller RTA1250; Woods Landscape Rake LRC60
Dec 20, 2011
Maine, Maine, US
On the question of whether the turnbuckles should be on the inside or out, I just installed the three point hitch on my new BX 25 (by the way, is it wrong for a grown man to be in love with a machine??).. Anyway, on my unit it's an inside job. I've attached a scan of the assembly instructions.
Bob
