L2900 power steering cylinder
waltweems
L5030, L35
Nov 10, 2015
10
cooksville
I'm removing the cylinder because of a leak and need to know how to remove
the pin in the rod end stopper below the radiator. There is a odd looking cap on top of he pin and I'm not sure if this cap is removed.
Thanks,
Walt
waltweems
L5030, L35
Nov 10, 2015
10
cooksville
Thanks Wolfman I got it off and I'm taking it to the dealer for a rebuild. When I reinstall are there any alignment issues I should be aware of?
Thanks,
Walt
6,210
Thanks,
Walt
If you just pulled the cylinder, nope, no realignment necessary. ;)
^Space^
L2900, Massey Ferguson 50E
Aug 30, 2020
Thanks,
Walt
What is the actual number on the hydraulic cylinder
5,199
1,885
i've been into about a dozen of these things this summer. Out of those, a good majority of them, the cylinder bores were worn beyond a reasonable rebuild. Make sure the shop you choose to rebuild the cylinder measures the bore of the cylinder and the bore of the gland where the rod protrudes before ordering/installing parts otherwise you'll be doing it again soon. New cylinder is expensive but it's also an updated part that to my knowledge hasn't had a failure (yet...we'll see in another 20 years or so).
^Space^
Aug 30, 2020
I understand but the traitor, though is 22
^Space^
Aug 30, 2020
Has only 390 hours on it. I would think the cylinder would be better than that. Although, if the part is an upgraded one it would be worth getting as I hate doing anything twice. But I have no part manual and do not know what the part number is. If you can help.
