GBJeffOH
L4060, EA Grapple, 6' LP Brush Hog, 8' snow plow, 6' LP tiller, EA Forks, Spraye
I could not keep the chain tight. You have a pivot with a jamb nut that you tighten to 400 ft. lbs. There is a 1/2" diameter rod that goes against the chain. I tighten the nut up with a 8' pipe on the wrench.
I had a friend machine a spacer for the idler sprocket.
Part #23 is the rod that goes against the chain.
