I have a 1999 kubota M 8200 and pto clutch is slipping . Pressure gauge is reading 400 psi, it will turn the pto but there is no power. Do you have to split it apart to install PTO clutch on tractor or can you do it from the rear? Thank you....
After splitting the tractor and rebuilding the pto clutch and controler the pto won't shut off. Need to check the correct pressure on controler? Thanks
