I took my injectors from my 77 B7100D to an injector shop, they said they all need to be rebuilt because they are leaking and the cost to rebuild all 3 is $165!!
I am weighing having them rebuilt vs. buying new and here is what I find on new ones. One thing I am not sure of, the replacement injectors are called "nozzle holder", is this a complete injector or just the case?
Assuming these are complete injectors here is what I found.
The #1 injector with single overflow outlet original part number 15271-53000 is replaced by 70000-65208, these are $40.56 shipped. #2 and #3 injectors are original part number 15271-53020 replaced by 70000-65209, these are $63.91 shipped.
I am assuming that the only difference between the two parts is the overflow on #2 & #3 being a Y ?
2 questions
1) any benefit in having my original injectors rebuilt?
2) would it work to order 3 #1 injectors (70000-65208) and use my original Y overflow fitting?
With option 2 above total cost would be $121.69 whereas rebuilding my injectors is $165, I would save $43.31.
edit - looks like 70000-65208 does not come with the hose barb ring (see attached pictures) while 70000-65209 comes with the Y hose barb ring.
Would appreciate if anyone can comment as to pros/cons of new vs. rebuilt injectors.
2 questions
