Hi folks, first post noob here.
Very nice forums, I've already benefitted by following some very good guidance.
I stumbled onto a 3 cyl diesel with 500 hrs from the original owner. It has the 54" deck and the awesome blower bagger. Picked it up for 2k with some spare parts and all manuals including oem workshop. I just went through the whole rig, every grease point, all fluids and filters. Old fluids looked beautiful, but I flushed everything even coolant. New tires, went one size wider at 9.5s and love them. Not sure why they went to narrow 8.5" as stock, plenty of clearance one size up and appears 10.5s could even fit. New front wheel bearings, adjusted all levers to smooth. Everything went well and works and impressed with my first orange tractor. I completed all checks in the manual and everything easy to understand.
TLDR - ***brakes*** anybody remove the brake pedal? I greased that fitting, but notice a ton of play/wear. Wondering if someone can confirm there is no bushing? I don't see one in the online parts catalog. I'd be surprised if Kubota went steel on steel with nothing serviceable.
***Shut down*** my machine doesn't always stop by the key, so I have to pull this lever thingy. Occasionally it will shut down. Any ideas or first things to check?
***Date?*** I have SN 121xx something or rather, anybody close know their machine mfg date? The air filter might have a date code of "Oct 94", not positive. Curious how old my rig is
Between the four wheel steer and the extreme build quality, I'm just enamored by this machine. Planning for drive shaft rebuild and new enamel for the spring. Already secured a couple critical used spares, and not many needed on this mini-beast.
UPDATE - ***FRONT WHEEL BEARINGS *** local dealer and I looked up the bearings and when I got home noticed there was no snap ring. Found the LATEST part number of #70000-00399, which includes the snap ring. NOTE - you cannot just use the number on the seal of the bearing you take out, that number doesn't include the suffix for snap ring (SR in bearing PN). So actually John Deere used this same size bearing with snap ring in some of their units, local JD dealer had two of these in stock where Kubota dealer had none. I wanted to replaced all four as one was "crunchy". I found 4 bearings to my door next day on amazon listed as John Deere #AM102888. These are the Chinese knockoff version. I found to be great quality, look like the original with snap ring and fit perfectly. Old bearings each came out with 6 taps of a 4lb hammer. See updated pics for bearing details.
Also have:
Massey Ferguson GC TLB 2018 ~200 hrs
John Deere X380 2021 ~ 120 hrs (this one, gonna dump it I think)
Also have:
