The owner's manual says I can use either UDT fluid or SAE 80-90 gear oil, with a capacity of about 7 quarts. My tractor has about 2300 mostly trouble-free hours and is 22 years old. I've always had a little UDT fluid that drips out of the left front axle area. It's low, so I have to top it off with UDT fluid, which is what I've always used, but I am wondering if switching to gear oil might be a better option for me. I'm thinking it's a bit heavier than UDT fluid and might fix the drip, drip. My understanding is that the front axle and gears are isolated from the UDT fluid I use for the hydrostatic transmission and rear differential, which is why the manual offers the option.
Thanks in advance for your response.
