fluid for front axle case Kubota L 3130
tick magnet
L3130 HST with loader
The owner's manual says I can use either UDT fluid or SAE 80-90 gear oil, with a capacity of about 7 quarts. My tractor has about 2300 mostly trouble-free hours and is 22 years old. I've always had a little UDT fluid that drips out of the left front axle area. It's low, so I have to top it off with UDT fluid, which is what I've always used, but I am wondering if switching to gear oil might be a better option for me. I'm thinking it's a bit heavier than UDT fluid and might fix the drip, drip. My understanding is that the front axle and gears are isolated from the UDT fluid I use for the hydrostatic transmission and rear differential, which is why the manual offers the option.
Thanks in advance for your response.
tick magnet
11,355
Yes, you can try it.
Better option, replace the seals that are leaking.
4,287
When my left front bevel-case began to leak…. I replaced the seal myself as it was not rocket science. (although I learned that seal is not as simple as I thought either… it’s a fairly sophisticated combo seal)…. then I filled the front axle with 80W90.
All is still happy 3 years later.
(Here’s where I posted my experience: https://www.orangetractortalks.com/...-case-oil-seal-replacement.56731/#post-536520 )
Trash Panda
L2501
Feb 18, 2022
302
284
Wyoming
Changing fluid types will not fix a leaking seal for the same reasons that all the various “mechanic in a can” products aren’t a solution to any problem.
Fix the seal, and then you can fill it with either. I personally run whatever product I have sitting leftover on my shelf from other projects. This last go-around, it was some SUDT2, but I absolutely would have had no problem running gear oil if I had the requisite amount sitting around.
