B8200DT Power steering upgrade
Orange.Tractor.Guy
Kubota B8200D
Aug 27, 2026
North America
Hi everyone, I'm new here. Used the forum a few times, lots of good info on here and finally thought I'd join up. I picked up my new project last year, a late model B8200DT with a factory loader and rear mount blower. The tractor has been great, and I have been doing some maintenance to get it all sorted. The only thing that I wished I had was power steering. So I've been looking at info on what others have done as the factory power assist was very rare and expensive. So I was trying to find a solution, then came across Fatjay's thread about him using a custom power steering setup. I am trying a different route and scored a b9200/b2150 power steering unit with the pitman arm and drag link. Is there anyone out there that has attempted this upgrade? The only thing im in need of right now is one of the power steering lines from a b9200hst "66363-41610". If anyone is parting out one or has the part please send me a message.
5,492
Sounds like a cool project!
Wish I more info, but I don't.
Could you have that line made locally? That might be easier/cheaper/faster?
Don't forget to post pics of your project......we love pics!!!!
sdodder
Kubota 1400H, JD GT262, JD 325, 2 snow blowers
Jun 28, 2026
New Paltz, NY
Good morning- In my area there are several places that can make custom hydraulic hoses. I'm familiar with 2 of them, they're auto parts stores. They have hose, all kinds of fittings, and the equipment to put it all together. I THINK at least one of them is a NAPA auto parts store-
Good luck with your project, Steve
Orange.Tractor.Guy
Kubota B8200D
Aug 27, 2026
North America
Right on, thanks for the replies. There isnt much space to run crimped hydraulic lines without them all getting in the way. I obtained two nos lines but one is for an hst and the other is for a geared one. The geared one is too long. I was debating on trying to modify it as well but i feel its easier to just get the right line. I dont want crimps and bunch of fittings that will leak over time. These original hard lines will last (in theory) for the life of the tractor. Besides all the linkages and stuff in the way its tedious to stuff it all in there. Are there any good known salvage yards people can recommend? I read somewhere on these forums a member, MountainMan has a bunch of kubota's?
7,678
Might send a message to "Mountainman" on this forum. He has some salvaged tractors in Alabama (I think).
Orange.Tractor.Guy
Kubota B8200D
Aug 27, 2026
North America
Ok so I had some more time to make some progress, so the column/box itself lines up on all 4 studs on the trans housing. Geared units have a flat angled top whereas the hst have a "dished" top. the hst also has longer studs from factory. I point this out because the b9200/b2150 power steering gearbox has a wider casting so it may have issues installing on an b8200 hst. 2 holes will need to be drilled on the tunnel itself as the power unit has 2 dowels installed. You could try to remove the dowels but i figure they are there for a reason so i'd rather drill it.
Orange.Tractor.Guy
Kubota B8200D
Aug 27, 2026
North America
I was trying to test fit the fuel tank but it will need to cut and welded or put a different tank in. Looking over the catalog the b9200 fuel tank or b7200 manual (geared) fuel tank. Would anyone have the dimensions on the b7200 manual geared tank? It looks tall and skinny and might be the better choice.
