Adding led rear lights
rkh Kubota
Kubota L3302DT
Sep 30, 2024
24
Pennsylvania
I have theL3302DT and want to add led to the rear for back blading snow when it's dark. Do I hook it up to the lights or the fuse box? Also a separate switch or hooked to existing lights?
JasonW
861
582
Al
There are plenty of ways to achieve this just have to research on what you want.
Just adding rear lights I would add a switch off the work light wiring and to the lights.
I’ve added a aux fuse block to run several different things.
Always run fuses and proper wire sizes. Learn about amp ratings. Don’t skimp and risk burning down your tractor.
John T
May 5, 2017
1,329
845
under a rock
I would buy a good quality set of LED lights (rigid or Black oak etc)
they will come with wiring/fuse/relay/switch.
(wires directly to the battery)
I'm sure plenty of guys will say cheap chinese Amazon LEDS are great.... but that has not been my experience.
I buy quality. Buy once... Cry once :cool:
11,114
The tractor should already be prewired for work lights.
rkh Kubota
Kubota L3302DT
Sep 30, 2024
24
Pennsylvania
Since I'm just a simple guy with no electrical degree, is the work light option in pink the available hook up for lights? My manual says there's Accessories outlet, but I couldn't find one. Is it only avaliable on the HST(mines manual transmission)?
JasonW
861
582
Al
Look underneath the rear fender. Cannot remember which side it’s on. The wiring should be tied around the flasher wiring. Thats the accessory outlet.
OntheRidge
Nov 1, 2020
498
589
Should be left side.
Bearcatrp
Mar 28, 2023
1,382
1,005
Minnesota
I went with a light bar that plugs into my cigarette lighter. I attach it to the ROPS.
