Speaking of abuse.....
Trash Panda
L2501
Feb 18, 2022
253
247
Wyoming
I’m sure Belzona makes some absurd product that might be able to glue it back together successfully. For a little while. Maybe.
Im also sure that said Belzona product will cost more than a new knuckle.
hagrid
K1600GTL, ZX-14R
Jun 11, 2018
1,173
1,772
Pittsburgh
Two zip ties will have that machine prowling the manicured lawn in no time.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,437
636
Richmond, Virginia
We used to use a length of clothseline. Tie one end to each hub. For power steering, put about five turns from each side around the drive shaft, tighten up in the side you want, it'll be like a capstan on a ship. Trust me.
4,175
I actually HAVE successfully MIG welded such things. I was ignorant of all the advice it “cant’ be done” …. and “won’t last” …. and I am not a real welder….. So, I welded it out of stupidity….and operated that tractor another ten years before letting it go to the next ignorant owner 5 yrs ago who is using it still to this day.
(Cast-steel is not as troublesome as cast-iron and can be successfully-welded if pre-heated. One method is to run a bead in an adjacent, but unimportant area on the part first…. the heat will “soak” the area of the part to Actually be welded.)
Trash Panda
L2501
Feb 18, 2022
253
247
Wyoming
Recreating the proper taper in that particular break is far more problematic than welding the break would be.
10,929
Fun fact, you can take a carbon water filter element (like a refrigerator) make a taper part on the lathe and use that to keep the weld out of the taper.
I've done it several times on parts broken across a hole.
