Again, suspect incorrect front brackets and/or improper installation adjustments.My deck is touching the frame and the hole is still a half inch off
Most dealers will not take the time to properly adjust things upon installation.
I went through the entire adjustment procedure maybe a week ago, with it adjusted correctly its actually further offAgain, suspect incorrect front brackets and/or improper installation adjustments.
Is it hitting on the bottom?
If it were mine I'd be running a drill bit through the hole and carrying on.
I probably can, i just haven't gone that route yet, I'm not particularly upset about it not working, because yeah it does hang down quite low, i was mostly making this as an informative post for anyone who was considering buying an lx2620 and wanted to use the mmm and the 3 pointView attachment 175913
Why not just fix it with a drill?
I don't have a mmm, but from what others have said here, many people take them off when they aren't being used to improve ground clearance.i was mostly making this as an informative post for anyone who was considering buying an lx2620 and wanted to use the mmm and the 3 point
I see what the problem is now. You are missing the part the pin goes through. I raised mine to look at it and at full height it is a little above and forward of the holes lining up. Mine has a silver tab bolted to the frame hole.
