looks like it's a pin on only grapple ??
A more specific link- https://www.anbomfg.com/mechanicalgrapplelooks like it's a pin on only grapple ??
While not a heavy duty grapple by any means this one answers most of your questions.Interesting design.
At 388lbs I think it's a little big for a BX or the smaller B series.
Maybe they will design one for the sub compact tractors.
The subcompact market is a lot of equipment.
The other question is can you leave the grapple on the loader and take the loader off the tractor?
Being able to do that would be a big plus.
That make a lot more sense, They need to point that out, using an SSQA of the same color hid it.I spy with my little eye….
I like the design, super simple to operate I’d bet too. I dislike the top links attached to that bar ran through the loader frame.
I did see the connections after I posted. I agree, it’s still a neat design. I feel the top links and long bar on lower tines would pretzel pretty quickly with real world rake use.That make a lot more sense, They need to point that out, using an SSQA of the same color hid it.
Your still need to manually disconnect the link and the pipe.
YOu should have also spied the third function so no need for that contraption.
Just watched some you tube videos that was posted on the kbx web site. Not bad for the BX series. May consider one.While not a heavy duty grapple by any means this one answers most of your questions.
KBX Talon – The Grapple Attachment for Kubota BX (2013+ Quick Attach)
Designed specifically for Kubota BX series tractors (2013 and newer with quick attach), the KBX Talon combines power and ease with an innovative, patent-pending linkage system that lets you take on tough jobs without needing an extra hydraulic channel. Get the versatility of a grapple without the cowww.littlebuckloader.com
