Lx2620 buyers be aware
LX2620guy
Lx2620
May 6, 2026
25
17
PA
I just got my 60" deck, it works great but be aware that you cannot pin the deck up, the holes are about a half inch off and according to the service rep that is the way it is, they want you to remove the deck for 3 point work.
PaulL
B2601, MX5200.
Jul 17, 2017
2,781
1,778
NZ
Very dubious about that. I mean, maybe, but that's quite un-Kubota-like. But it is quite service rep like.
Can you redrill the holes? Are you really sure there's no way to align them?
LX2620guy
Lx2620
May 6, 2026
25
17
PA
Oh apparently it didn't post my photos, but without getting really creative, no, theres no good way to just make it work
10,782
Post your photo's, because what your saying makes absolutely no common sense.
Kubota wouldn't make a way to pin up a deck then make it not line up on purpose!
10,782
Are you using this button?
If they won't load it will tell you why.
bird dogger
Vendor Member
Feb 24, 2019
1,782
1,758
North Dakota
new member minimum post requirement before posting pics, maybe?
bird dogger
Vendor Member
Feb 24, 2019
1,782
1,758
North Dakota
I thought it used to be just 5 posts before a new member was allowed to post pictures. You should be good to go....unless things have changed.
10,782
Is it hitting on the bottom?
If it were mine I'd be running a drill bit through the hole and carrying on.
LX2620guy
Lx2620
May 6, 2026
25
17
PA
No, its hitting in another spot on the deck, they have a nice oval hole on the frame side but it just doesn't line up. I may end up drilling a hole but before i went modifying a brand new deck i figured id at least ask the question, the deck is an rck60-30bb, i was wondering if anyone has the revised rck60-30bc and if that deck has an extended bracket to make that hole line up
Bearcatrp
Mar 28, 2023
1,331
973
Minnesota
Well that blows. May have to rethink my possible purchase of that model. Can’t believe Kubota would screw this up.
