3rd function valve kit Kubota bx1880
Bearcatrp
Mar 28, 2023
1,299
949
Minnesota
Post what you decide on. Been wanting one for my 1880. Dam dealer wanted one of my kidneys, left testical, and a lung to install one on mine.
If I rember right, they wanted $1600 to install one for my 3 point.
Ping
BX2370-1
Dec 25, 2018
361
374
Troy, Ohio
Or, you could keep all ur body parts and just cobble a diverter together like I did for not much $.
Surplus Center valve, McMaster Carr switch and a couple hoses. The original curl hoses were a perfect fit to supply the diverter valve. New hoses needed from valve to curl cylinder. It's not a true 3rd function but, works for me.
CBHOM
BX1880, LA400
Apr 22, 2026
Minnesota
I'm new to tractors could you put together a install instructions for a 3rd point. I would like to do like you did and cobble a diverter together . Thanks you so much! I would need a parts list too please.
6,926
Dont do it. Buy the Summit or WR Long kit and follow the simple instructions.
Bee-Positive
Nov 16, 2022
749
748
Amsterdam, NY
That's why most get it installed at the time of purchase wrapped into the tractor financing.
This begs the question - what are you going to use the grapple for?
Putting a grapple on the BX1880 is not going to lift trees trunks especially after subtracting the grapple weight. The loader is just not that good. Maybe some brush and what not but only a couple hundred pounds. I just bolted some 2x4's to the bucket and am surprised how well it works moving brush. I just have a few acres so I'm not doing a lot, maybe once a year. Don't forget to add rear ballast.
Blue2Orange
Apr 3, 2025
393
276
Bayview Township
IIRC, my local Kubota dealer charged mid to high $800's when purchasing the BX. Incentive price to buy now? I made the mistake ~25y/o ago not buying the Loftness snowblower with the then new NH. Year later and add $600. Really like the grapple claw. Makes life nice when moving logs and brush piles. Was considering a QA pallet fork, but unsure about use for hauling and moving logs. Might be an option for those not wanting to invest in a 3rd function?
Bearcatrp
Mar 28, 2023
1,299
949
Minnesota
Adjustable pallet forks work great for logs and brush. BX is too small for a grapple. Just make sure you have good lbs of ballast in the rear. With 300 lbs in the read of mine, can lift max weight with my 1880.
