Help with L35 leaks and ROPS/Cabin removal
Firewood
B7100 (tiller and flail mower); L35 (front loader, back hoe)
Apr 21, 2026
Victoria, British Columbia
Hi there,
I just bought a new-to-me L35 with the front loader and the back hoe. It also has the "Laurin Vision Plus Cab" which I'm not sure how I feel about yet, but it is an enclosed cabin with heater, radio etc (I'm a minimalist by nature). It came to me with pretty substantial hydraulic leak that I originally though would require splitting the tractor but after doing some reading I think its probably the hard lines above the transmission (and there's also some hoses for the backhoe that need to be replaced and a leak from the loader control valve which I hope doesn't require replacing the unit).
I would really appreciate some help with this. Any tips would be great. Even removing the cabin seems like a huge pain in the rear. From what I can get from the service manual I got is the ROPS/Cabin has to be lifted off, then the floor lifted off, then I can run the machine and confirm the leaks and have access to repair. One post said the hard lines were a bugger to get in and out and someone said they modified theirs with fittings and some braided line? Is there anything recommended that I do while I have access to these areas? I have split the b7100 before to do a clutch and it was so much simpler and nicer to work on.
I'm just about to go outside and finish welding up a gantry to lift the cabin off. I'll only have room to raise it up about 2-2.5 feet.
Thanks and wish me luck!
L35
Jun 13, 2010
690
796
CT
Post pics of the areas in question.
6,237
Get the installation manual for the cab ! It should show you how it can be removed, having a tall gantry crane would make it easy.
As for the lines, there HAS to be a way to do it,fairly fast. Just think 'assembly line'. No way it should take more than 5 minutes to 'feed' it into position.
Firewood
Apr 21, 2026
I’m always short on time but I got the gantry finished and started taking things apart. Apparently the cabin is kind of a custom add on but I should have it off when I’m able to get back out to the shop. Then to lift the floor off it looks like like it could be tough because the cabin will be suspended a couple feet above it. I might be able to rig up and extension for my engine hoist to get in there. I have the Kubota service manual but it looks like it was a scam so the pictures are very poor quality.
2,841
There is a Kubota site for illustrated parts lists that can help you see how things are put together.
I think you have to go to the Canadian site
Workerbee
Zd21
Mar 1, 2020
351
217
MN
Is it possible to remove your wheels and lower the tractor down a ways before lifting your cab? Maybe you could gain 10-12”?
