Help with L35 leaks and ROPS/Cabin removal
Firewood
B7100 (tiller and flail mower); L35 (front loader, back hoe)
Apr 21, 2026
Victoria, British Columbia
Hi there,
I just bought a new-to-me L35 with the front loader and the back hoe. It also has the "Laurin Vision Plus Cab" which I'm not sure how I feel about yet, but it is an enclosed cabin with heater, radio etc (I'm a minimalist by nature). It came to me with pretty substantial hydraulic leak that I originally though would require splitting the tractor but after doing some reading I think its probably the hard lines above the transmission (and there's also some hoses for the backhoe that need to be replaced and a leak from the loader control valve which I hope doesn't require replacing the unit).
I would really appreciate some help with this. Any tips would be great. Even removing the cabin seems like a huge pain in the rear. From what I can get from the service manual I got is the ROPS/Cabin has to be lifted off, then the floor lifted off, then I can run the machine and confirm the leaks and have access to repair. One post said the hard lines were a bugger to get in and out and someone said they modified theirs with fittings and some braided line? Is there anything recommended that I do while I have access to these areas? I have split the b7100 before to do a clutch and it was so much simpler and nicer to work on.
I'm just about to go outside and finish welding up a gantry to lift the cabin off. I'll only have room to raise it up about 2-2.5 feet.
Thanks and wish me luck!
L35
Jun 13, 2010
727
838
CT
Post pics of the areas in question.
BX23-S,57 A-C D-14,
6,331
Get the installation manual for the cab ! It should show you how it can be removed, having a tall gantry crane would make it easy.
As for the lines, there HAS to be a way to do it,fairly fast. Just think 'assembly line'. No way it should take more than 5 minutes to 'feed' it into position.
Firewood
Apr 21, 2026
I’m always short on time but I got the gantry finished and started taking things apart. Apparently the cabin is kind of a custom add on but I should have it off when I’m able to get back out to the shop. Then to lift the floor off it looks like like it could be tough because the cabin will be suspended a couple feet above it. I might be able to rig up and extension for my engine hoist to get in there. I have the Kubota service manual but it looks like it was a scam so the pictures are very poor quality.
3,173
There is a Kubota site for illustrated parts lists that can help you see how things are put together.
I think you have to go to the Canadian site
Workerbee
Zd21
Mar 1, 2020
394
278
MN
Is it possible to remove your wheels and lower the tractor down a ways before lifting your cab? Maybe you could gain 10-12”?
Firewood
Apr 21, 2026
finally found a bit of time to work on the tractor. I got a gantry and got the big heavy cabin off and started working towards removing everything to get the floor/fender assembly off. I have two questions:
1) I’m following the shop manual but the steps are to access and split the transmission so i think i can skip some steps. There’s a lot to removing the instrument panel frame (power steering hoses etc). Does anyone know if I can leave that all attached and just raise the instrument panel frame enough to slide the floor backwards and out from under it?
2. while I only have stuff off I was trying to see if I can locate the leak. It seemed to be from the top right side somewhere on the transmission housing. Now it’s not leaking but in the shop I can’t drive it at all. But moving loader etc wouldn’t it dripping and neither would putting it into either backhoe 3-point mode with the diverter valve. I put it in forward/reverse and moved the 4 inches or so I can move it where it is and put load in it with the brakes on and no dripping. Is there something there that could leak only when actually travelling?
Thanks!
3,173
You might try jacking the rear tires off the floor and putting it in 2WD and see if you can exercise the transmission enough to get it to leak.
But I suggest that you get information on what those lines do and what would make them leak and try that operation instead of just trying one thing after another.
Have you located the lines in the parts list? That might give you an idea of what the lines are for. I would think that all transmission flow is internal except for cooling lines that go to the front of the tractor and back.
Firewood
Apr 21, 2026
Okay good news and bad news. Bad news is I wasted a bunch of time following a book when I should have just done some exploring. There’s an access plate under the rubber matting under the seat. The good news is the leak is coming from one of the steel hydraulic lines that comes out of the front of the transmission housing near the top. There are two lines stacked on top of each other and it’s the one towards the front that seems to have a hairline crack where the line is brazed to the connection. It looks like it might be an adventure to get it out but I assume it is possible without removing the floor pan/fender assembly. Kubota said the part is discontinued so hopefully the hydraulic shop doesn’t have trouble brazing it back together.
11,355
Oh now you're in for a fun time. 😋
That is not an easy line to get out!
7,400
I am going to guess that is welded not brazed.
L35
Jun 13, 2010
727
838
CT
Anyway it can be replaced with a hydraulic hose?
5,515
2,231
probably but you'll have to find someone to make it with the correct ends. Likely less $$$ to just buy the OEM pipe and install it. You still have to take the old one off so just get the correct one and have it on hand for when you get the old one off.
the hose idea is sound but remember that the hoses often dry rot long before that pipe cracked.
Firewood
Apr 21, 2026
Okay so the hard line is replaced. For anyone’s information reading:
Only the front was leaking. Apparently these aren’t supported anymore so they have to be repaired. Mine had a small hairline crack where the hard line went into the connection. The hydraulic shop brazed it and it was a cheap easy fix.
As far as getting it out I could gave saved myself a lot of time by ignoring the manual. I had to get the big aftermarket cabin off but after that would have ignored everything except remove the seat, the access plate under the seat, the gear shift cover. I removed the four large floor/fender bolts and just gently lifted up the back right side corner of the floor/fender assembly a bit and was able to pull the hard line out of the access panel under the seat.
Now I have to replace a bunch of hoses in the backhoe (probably will just do them all to save myself headaches as the hoses go one by one). Anyone have any bot tips on that? The hoses going through the boom look like a pain in the ass.
Firewood
Apr 21, 2026
Also the manual shows the little flathead screw on the front of the hard line as being directional valve #1 for the front loader system. As you can see mine is unmoved and sitting almost in between. When I removed the line I didn’t take a close look by I assumed this this a bleeder or something. Can someone confirm that I should put it yo the position with a front loader?
thanks
3,173
If you have a FEL then set it as required.
It diverts fluid to external hydraulics or directly into the tractor when no external hydraulic elements are installed. It is similar to the replacement block shown in post #1 of this thread.
Joisey
Kubota L47 TLB
May 31, 2015
261
185
Wild, Wonderful West Virginia
If I may, different colored zip ties help with connecting the correct line to the correct fittings. Pictures can be misunderstood. Zip ties are cheap and positive.
