So I was taking my “new to me” rotary table down stairs to the shop, when the hub for the wheel on my Chi-Com HF hand truck cracked.
Luckily it did so before I hit the stairs, but now I gotta replace/fix it.
Now before we get started, I am FULLY AWARE that a replacement wheel is like 20 bucks and that there is a Horror Fright store less than 5 miles from me.
However, the store won’t open for 4 more hours…..so……I get it in my head that I should/need/want to fix this damn thing…….So off we go…...
(Having technical difficulties posting pics right now……………to be continued…..)
well……I found a “work around” for loading pics…..for now anywhooo, so…... “The Show must go on!"
Well here is the crack.
I tried to just snap it off, but I was just bending the hell out of the rim,
So grab the cut off wheel, ….but…..won’t reach…..damn it!!!!!
So what the hell kind of RWS post would this be without a picture of his lathe?
As you can plainly see, it's pretty "jacked up"
So I chuck the “rim” up and “Jerry rig” (or is it "Jury rig"????) a boring bar to cut it off.
a few seconds later it’s off.
I then took a few passes to “clean things up a bit"
Now I will just “re-weld” it and BAM….I be done!!!!
Well as soon as I got that torch even close to that "paper thin” part, it melted it so fast, I couldn’t believe it. I tried heating the axle before I “walked it in” , but no dice…..that thing was toast.
Maybe an actual welder could do this, but my “weekend warrior hack-ass” wasn’t gonna be able to pull this off……..
Time for plan B….
As I contemplate my next move, I look at the time, and now the store is only 2 hours from opening….Hmmmmm….better get my ass in gear…...
So as I am looking around for solutions, I see out of the "corner of my eye’ a 3/16’ish plate of scrape “mystery metal” that I was making .22lr targets out of, and it hits me……….
Why not cut a “circle” out and weld that to the hub and use the existing bolt pattern to simply bolt it all together……Kind of like a “sammich” …..
Brilliant!!!!!!…….But how should I proceed with making/copying/drilling the proper bolt pattern?
Hmmmmm……..Is this a good time to learn how to use one of my 2 rotary tables?????
Probably is…..but I’m just not “feeling it” right now, ….the "store opening” somehow becomes my “White Whale”….for some strange reason……I have nothing to prove, but I want this done before that damn store opens; Come “Hell or high water”…..
So I decide to cut it out using the CNC Plasma machine……
So I run up the stairs, open that computer, and in mere seconds I proudly have this…...
(as a side note; I’m not too "half ass'ed bad" with that Alibre program now…..I even upgraded to the Mac-Daddy "Expert” version recently
PRAISE THE LORD!!!!!!!!
I am going to make my “artificial/made up/no good reason deadline”, after all. !!!!!!
RIGHT!!!!!!
But that’s where this story takes a "sad turn"…………...
Time for plan B….
RIGHT!!!!!!
