BX2752 Mid-PTO Drive
NN2B
Kubota BX1870, LA203A Front-end Loader, Land Pride BB0548 Box Scraper
Oct 13, 2025
Woodland Hills, UT
First-time Kubota owner here. I have a BX1870 from 2013. There’s a used snowblower package for sale near me. It has the BX2750D snowblower, BX2751 front quick hitch, and a BX2753 mid-PTO drive.
I know the BX2753 mid-PTO is the wrong one for my BX1870, so I’m looking for the BX2752 which I understand is the correct one. But all I see online are the parts diagrams for it; I just want the entire thing.
I look it up on Messick’s and all I see is an exploded diagram. So I’m confused - do I have to buy all the parts and put it together? Is it not sold as a single unit?
7,187
I would maybe start by looking at the Operator's Manual for the BX2751.
I believe the only difference in the BX2752 and BX2753 is the length of the drive shaft. 2753 is longer/2752 is shorter.
However, while the same parts, I think the pillow bearings are oriented differently between the two.
2️⃣
NN2B
Oct 13, 2025
Woodland Hills, UT
Are you saying maybe I can take the BX2051 Quick Hitch and replace it's 8-3/8" shaft with the shorter 5" inch one? That way the existing longer 2053 mid=-PTO drive shaft would fit?
10,233
Both the BX2752 and the BX2753 fit the BX1870
The BX2753 has a heavier front shaft and heavier bearings.
NN2B
Oct 13, 2025
Woodland Hills, UT
So...I'm either getting conflicting info, or I'm confused - or maybe it's both. Some say the BX2752 and BX2753 mid-PTOs are the same length, some say they're not since the 2752 is for the BX18-series and the 2753 is for the BX23-series tractors.
The photos above from RCW's manual (thank you, btw) show the BX2751 front quick hitch, but it shows two, each with with different shaft lengths. Can someone clarify?
What I'd like to find out is what I need to make this used BX2750D snowblower, the BX2751 front quick hitch, and the BX2753 mid-PTO drive work on my BX1870 tractor.
Thanks!
Sawdust&Shavings
BX1870,LA203A,BX6315,BX2767,RCK48-18BX,GCK60-23BX
Apr 25, 2023
155
168
Stafford, VA
What I'd like to find out is what I need to make this used BX2750D snowplow, the BX2751 front quick hitch, and the BX2753 mid-PTO drive work on my BX1870 tractor.
Thanks!
I don’t have your answer, but the BX1870 is narrower and shorter than the 80 series BX1880 (et al) through BX23S. The frame at the front of the BX-1870 is also mildly different, so it doesn’t surprise me that there may be slight differences in shaft length.
NN2B
Oct 13, 2025
Woodland Hills, UT
So an update - I bought that used BX2750D snowblower package last night (it came off a BX2660). And I did confirm that the main PTO driveshaft (at 44.5 inches) is the same one that will fit my BX1870.
But the splined shaft inside the BX2751 quick hitch subframe is the longer one in the diagram above (8-3/8"). So I'm concluding I'll need to replace the shaft with the shorter one (5"). I mean, what other options are there?
I'm going to dry-fit everything in the next week and see how things line up, but does that seem to make sense?
MessickFarmEqu
All of it
Apr 16, 2010
PA
www.messicks.com
FYI, you are spot on.
NN2B
Oct 13, 2025
Woodland Hills, UT
Thanks for the confirmation, Messick. I did dry-fit things on Saturday, and yes, I need the shorter splined shaft.
I think part of my confusion comes from the fact that first, I'm a beginner, and second, trying to decipher the model numbers of all the snowblower parts - the BX2750D snowblower, the BX2751 front quick hitch, and the BX2752 mid-PTO Drive.
The BX2751 is the part with either the long or short splined shaft, but as far as I can tell that model number doesn't differentiate between the long or short-shaft versions.
The mid-PTO drive comes in both the BX2752 (for my tractor) and the BX2753 (for longer tractors). Different model numbers, but apparently the drive shafts are both identical.
So I've been looking for a shorter BX2752 when it didn't exist. What I needed was the shorter shaft inside the front quick hitch, which, at the time, I didn't know was a thing.
Anyway, I've got the shaft and its bearings ordered. And hopefully they'll arrive before the next snowstorm.
Seane1987
LX2610SU TLB, BX2350
Jul 18, 2021
60
54
Lafayette NY
Wish I would have seen this sooner, I have the shaft you need, its yours if you want to pay shipping.
I ran into this when I bought mine, I have a BX2350 and bought a blower and hitch from a BX1860.
NN2B
Oct 13, 2025
Woodland Hills, UT
Dang. Yeah, well . . . mine's arriving Wednesday so it may be more of a hassle in the end, with all the shipping. Thanks though!
