Turned it one time too many.
texican
L3000F, FEL
Oct 12, 2023
87
19
East Texas
Anybody know of a good way to jimmy rig it for the weekend? Gotta a bunch to get done.
Also, where can I take it to get it re crimped once I have it cut off, assuming I can find another solid terminal like this one?
I called a couple of the battery stores, the said they had no idea. Called a couple of auto-parts store..same..no idea.
texican
L3000F, FEL
Oct 12, 2023
87
19
East Texas
I have to get work done this weekend before it rains tuesday and I really dont want to drop a $100 on a 35 in inch copper cable if I can get a terminal put on it.
9,405
9,405
Yeah, I think this may be the route, like you said, not ideal but that's what you get for overtightening things. Should be able to cut the solid one off with dremel.
It's only temporary .... unless it works! 😂😂
Reactions: 6 users
L35
Jun 13, 2010
611
595
CT
For the weekend a pair of vice grips clamped on there tight will do. If it’s the positive make sure it can’t contact anything.
2,367
Go to a marine shop or possibly an auto parts shop and get:
Battery terminal like this
Cable terminal like this
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,764
2,128
Near Lancaster, PA, USA
I picked up a new battery at Lancaster Starter and Alternator some time back and bought a few crimp battery lugs. Also bought some AL/CU lugs on Amazon when i made my jumpers. I had access to a crimp tool and it was a snap.
If you know an electrichicken they'd be able to crimp them for you in a minute. If not, maybe a rental center or buy a hammer tool like below. It's not like you're doing 5KV terminations.
9,254
I have marine terminals on all of my equipment.
I don't have battery cable conductivity issues.
PoTreeBoy
L35 Ford 3930
Mar 24, 2020
3,460
2,039
WestTn/NoMs
You obviously have a Walmart close by. They show a 4ga 32" cable for $8.52 in stock near me. Yours, don't know? I've seen the visegrip trick at least once. Or a C clamp. Or you could drill through the clamp and post and run a 1/4" bolt through there.
But I'd replace the cable and be done with it.
Speed25
L2501(sold) - BX25D
Apr 23, 2024
269
413
NC
Most truthful thing I've read on the internet in a long time...
I rigged up a battery connection on my truck to test out a few things. 11+ years later, it's still there, doing its job, untouched...
Mark_BX25D
Bx25D
Jul 19, 2020
1,876
1,365
One of these from Walmart? Not the best battery terminals but they work well enough to get you back to work.
Those things are JUNK!!!!
But they will get you by for a few days. No way I would ever consider it a permanent repair, but in a pinch? Get me through the weekend?
You bet!
3,170
This is one example of why I hunt garage/estate sales. (for years)
Between here and the cabin, I have at least twenty different cables, pos & neg, and probably another dozen or so post clamps, pos & neg, a couple battery disconnects, some anti-corrosion washers, & spare bolts/nuts.
Plus a huge assortment of cable terminal ends & crimping tools.
All new.
Probably don't have $30 invested in all of it.
Enough to cover virtually any situation that may arise.
Have helped out neighbors a couple times too.
9,405
I added a second (house) battery to my boat last year and ran a couple of 2 gauge cables from the rear of the boat to the console, about 15 feet. I bought an hydraulic crimping tool from Amazon and it has proven to be useful for other projects too. It has multiple die sets for all manner of sizes and if I ever need to crimp on a lug for a battery I'll be using this. I bought boxes of 50 each of 3/8" and 5/16" lugs for 2 gauge cable.
For a long-term solution, lugs in combination with marine type battery terminals works for me and has for years.
jaxs
B1750HST
Jun 22, 2023
969
747
Judging from marks on post and broken terminal I'd say they received a few beatings in the past. Could of been continuity issues, emotions 🤬 issues or combination of both.
