1980 B6100 4x4 - Looking for loader.
Swede1962
B6100D 4x4
May 3, 2025
78
42
Overland Park, Kansas
I have recently purchased a 1980 B6100 4x4. She needs a little TLC but this is what I enjoy doing. I'd like to find a loader and rear wheel weights. A rotor tiller would be good too. I'm in the Kansas City area but can travel for the right price/items. Thx for reading my ad.
Swede1962
B6100D 4x4
May 3, 2025
78
42
Try calling 1980.
A loader will cost more than that tractor. Sorry for the reality check.
Wow! Sarcasm? If thats all you have please keep it to yourself. Sorry if you have no appreciation for older equipment. No actually I'm not sorry. Smart ass remarks serve no purpose so again, keep them to yourself. I see a ton of people replying to questions on this forum with respectiful helpful responses. Yours not so much. You have a good day sir!
6,676
Welcome to the forum. I notice you reside on the correct side of the state line! I'm down south of Olathe 25 miles.
Mikester may have more direct then you like, but what he said about the loader is pretty accurate, but the real problem is not only finding the loader but you also need all the attachment hardware. There is a member here "Mountain man" who has some salvaged tractors and my be able to locate a loader for you.
8,793
Yes loaders for B6100DT and B7100DT's or really any of these 40 year old tractors is really hard to say the least.
One big issue is the drive for the pumps have long been obsolete, so you would need to modify the existing hydraulic system, and even doing that a loader is going to be slow to operate.
And rear wheel weights for them is equally hard.
If you do find a loader just do a ballast box for rear weight.
Swede1962
B6100D 4x4
May 3, 2025
78
42
The response from the other guy was not in my view worth anything of any value. Besides that being a condensending A-Hole doesn't sit well with me. I have placed him on ignore so it won't be an issue moving forward. I'm here to learn and build my machine. I can joke and roast with the best of them, I assure you. I appreciate the info on the guy with the salvage. If I have to I'm ready to fab one or have a loader built from plans or whatever I can get my hands on. And yeah, I'm in OP near 87th and Antioch. Nice to meet you neighbor.
Swede1962
B6100D 4x4
May 3, 2025
78
42
I have seen electric driven pumps that sparked my idea for a loader but it may all be a pipe drream. I'm used to playing with old equipment. My "other" yard tractor is a 1966 WheelHorse. I replaced the 6hp Tecumseh with a 15hp Honda. I pull a slotted disc and solid disc in tandem to work up the garden. Then a cultivator and a harrow to smooth out all the clumps before planting. Push snow with it in the winter time with a front blade. I even have a single bottom plow that actually works. Old stuff can work well if you treat it right. Heck I'm old!! ;-)
6,676
I bought a loader for a Massey and adopted it to an L305 a few years back. I had to build the entire mounting hardware.
You have to find a loader that has the width between the loader arms that are not too narrow and not too wide then start making parts. I remember the metric bolts used for attaching the frame to the tractor were over $125 back then.
Swede1962
B6100D 4x4
May 3, 2025
78
42
Found a real nice shape Kubota B219 loader in Oklahoma. Brought it home yesterday. Will build a subframe and re-hose the loader with a pressure gauge and return filter as well. The front spline drive for the pump is in great shape. I found a vendor for the drive attachment and pump. Will also be replacing the 2 lever system with a single 2 spool joy stick for easier operation. Things are looking up around here. 👍
ken erickson
Nov 21, 2010
1,261
2,190
Waupaca Wisconsin
Glad you found your loader and looking forward to seeing your build and progress.
Good on you for forging ahead despite the real or perceived obstacles expressed here. (y)
3,099
Congrats on your find, nice shape, not beat up at all!
3,099
For reference, here's a pic of the B7100 subframe.
Swede1962
B6100D 4x4
May 3, 2025
78
42
Appreciate the comments. I’m not detoured by nay sayers. Most that are like that have a high opinion of themselves and deflect downward to others ideas and suggestions. I’m the guy who is ready to prove them wrong. This is just another one of those times. 👍
Thank you. I’ll post pics as I move thru the process.
Swede1962
B6100D 4x4
May 3, 2025
78
42
Congrats for sure! How far did you travel to get that loader?
I drove 380 miles each way. Yup, 760 miles which turned out to be a 17 hour day. Broke a brake line on my old Jeep which the seller helped me repair. Couldn’t ask for a better bunch of folks to deal with. But in the end I have a B219 loader that is in the back excellent condition. 👍
Swede1962
B6100D 4x4
May 3, 2025
78
42
Id rather it on my b6200 but I do have a 6100!
Kubota loaders are out there for sale. Just gotta turn over some rocks to find them. I seen a post recently where a guy mounted an LA series loader on a 7200 I believe it was. Of course you’re back to building a subframe and a few different brackets but that’s where the fun is, right? 🥳
