I have a rear blade on my bx2200d when tractor is cold and you pull the 3 point hitch control to lift the blade you must hold on to it all the time in the up position, if you let go the blade goes right back down on its own. Once the tractor is warmed up the blade will drop sometime when the front end loader is dropped.
The rear hitch never lifts automatically and returns to center on its own. I must hold lever in up position then let it return to center very gently. Or it will go all the way back down.
I should be able to just pull lever to up position and leave go and when blade is all the way up return to center on its own.
Anyone know how to fix this?
