3pt hitch hook-up
Kubota_Man
BX24, Rear blade, Front blade, Snowblower, 54" MMM, Box scraper, Landscape rake
Dec 25, 2010
953
Kellogg, Idaho
Ok I have a green horn question.
On my LandPride RB1560 there is 2 holes at the top of the frame where the top link hooks-up. Why is there two holes and not just one? What is the advantage of using one or the other?
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
Here is a link to the owners manual. Scroll down to page 8. Multiple holes help you match it up to your tractor.
Hope this helps. :D
RBA50
B2320, LA304 loader (B1658 QA), B2789 snowblower, RCK54-29B MMM, HF quick hitch
Apr 29, 2013
133
20
Goldendale, WA
Generally, the top hole is used with the top link, the bottom hole is used if you have a quick hitch.
Tx Jim
M7040 HDC & JD 4255
Apr 30, 2013
1,210
133
Coyote Flats,Texas
May I ask what a QH has anything to do with the amount holes in the centerlink attaching bracket or which hole is utilized?? Centerlink attaching brackets had multiple hole locations long before a QH was invented.
On tractors with draft control the hole one attaches centerlink affects the sensitivity of the draft control. The hole used also affects the height & angle of lift of attached implement.
RBA50
Apr 29, 2013
133
20
Goldendale, WA
I'm sure you're right about the holes being there before QH's. However, many QH's are built to the "standard" spacing of approx 15" from lower pin height to top link point, and are not adjustable. LP advertises that the RB is QH compatible, and the lower hole is set at that height. Nothing says you can't use the top link there if it works better for you, or if you have an adjustable QH, that you can't use the top hole for that, if it matches your other implement spacing.
YMMV
Kubota_Man
Dec 25, 2010
953
Kellogg, Idaho
Please forgive my lack of proper terms.
I am referring to the fin looking portion of the of the frame that is closest to the tractor. There is 2 holes that the top link can hook into.
7,784
The multiple holes you are referring to are called the top link pin holes, they are the top links attachment point.
There are three different normal top link pin heights that equipment was/are made to, 15" (normally used on older tractors, I've seen it on Case, ford, Massy harris, AC, and MM and I bet others) 18" standard Cat 1 height, 24" normal Cat 2 Height.
If you measure the height from the lower pins to the upper pin holes the should fall in those ranges, I just always use the Cat 1 18" for my Kubota's.
An implement being QH compatible has to do with the ability to slide the top hook of the quick hitch onto a top pin (while at the same time engaging the bottom 2 pins), regardless of the height of that pin, most QH's will allow you to move and set that top hook to match what you've already using just for versatility rather then having them fixed at a set 18" or 24".
On the tractor, if it has multiple top link holes to attach to it has to do with draft control (semi automatic height control) and angle of blade attack on a bladed implement.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
If you also will note that using different top holes you change the configuration of the rhombus (four sided figure) so that you get different lift ranges for the rear blade. The lower hole likely will cause a higher lift end point.
