Hi guys, I am hoping you might be able to help a tractor newby in Australia with an issue with my 3 point hitch.
I have owned my kubota L2002DT for about 6 month, in that time learned about the grey market stigma and lack of documentation It has worked great for me this whole time, but has decided to start throwing a few challenges my way.
I have a 4 in 1 loader up front, and I have been using the 3 point for a slasher and more recently an auger. I have had no issues at all and have used it on a fairly regular basis. Last weekend I moved some soil with the bucket, parked it up beside the house when done and left it there until this weekend. The auger tip was on the ground as usual, but on starting up the tractor, the 3 point did not lift. No matter what I do I cannot get it to lift now.
I have checked and topped up the transmission oil, checked the valve under the seat to ensure it is screwed all the way to anticlockwise (this is what I was told when i bought the tractor), looked for leaks, checked the filter (cartridge filter at motor) but no sighs of anything untoward.
If I lift the 3 point up while the lever is up, I can lift the attachment in stages and it "latches"so to speak and holds itself. Once I have lifted it, I can use the lever to lower the 3 point as per normal, but it will not lift.
This is the valve that I was told to leave in the anticlockwise position.
Hydraulic filter with main line feeding into the bottom. Lines out of here are for the loader controls.
This is the take off to the hydraulic filter
Left side of the gearbox. I read somewhere on OTT that there is a inline filter here somewhere, I cannot find it though
Drain plug still wet after I fumbled with it when ensuring the oil was clean
Any advise would be greatly appreciated guys, I'm at a loss now, and my wift really wants those fence post hole dug
Thanks, Andrew
Oh, one last thing, what is this for??
Thanks, Andrew
