The suggestion about retro fitting with rops got me thinking about stability.
Along with basic wheel weights, would the addition of weight along the underside mid line add more low center of gravity stability?
Think a very heavy belly mower.
Or am I not thinking with the right physics?
If yo can sacrifice a little ground clearance, would putting the weight under the tractor serve any advantage to just using a ballast box on the 3pt hitch or the front end?
Just a random thought. I have piles of iron bench weights lying around. Fitting them under the mid line of the tractor would be fairly easy.
