what weight brand engine oil do you run
primerk5
Maryland
I'm just about done my rebuild on my d950 for my b7200.
I bought rotella 15 40 for it. I noticed in the manual it calls for 10 30 and was wondering what everyone else runs.
Is the travelers brand hydraulic fluid OK for the hst transmission.
Bluegill
Jan 11, 2012
1,559
Success Missouri
I run 15-40 in the L3800, but have run straight 30 in our old L3750 for many years. It's really not that big a deal as long as you have oil designed for diesel engines. I'll likely go with a lighter synthetic next change in the 3800...
Hydro oil? Use Kubota SUDT oil! Especially with HST trans!
SteveF
BX25
May 15, 2013
307
Huntingdon, PA
I use Kubota 15w-40w in my BX25. Have been using RotellaT 15w-40w in my Cummins with no problems.
Agree with Bluegill on the SuperUDT2 in the hydro.
10,604
The 15-40 should be fine that's what I run in my D950, great pressure and quiet.
I'll agree don't skimp use Kubota SUDT, other hydraulic fluid is usually too thick to work well.
Dan_R_42
B7100-D, w/ Sims Cab, B219 FEL, ARPS 70 Backhoe, Oversized R4 Tires, LX2610 Cab
Dec 1, 2010
447
Taunton, MA
I use Rotella T6 5W-40 Fully Synthetic Oil in my B7100 & the GoldWing GL1500
73blazer
G5200 w/46" Snow Blower,blade,debris blower;,L35;G1800S
Feb 16, 2013
24
Mid-Michigan
I use Mobil Delvac 1, it's a 5w40 synthetic made for diesels. (not regular Delvac, although a good oil, Delvac 1 is far superior)
In the cold, they start great! Great soot control, good hot weather performance and viscosity retainment...outstanding longevity, it's a top notch oil. $29/gallon at most truck stops. I change my tractors (L35 and G5200) once a year.
I also use in my newer Cummins and my older chevy 6.5TD which has 280kmi on the clock .
For hydraulic oil, can't beat super UDT2. While expensive, it shouldn't need changed all that much, kubota's done their homework that stuff, cold weather performance is outstanding, I've never had any issue with this stuff. I was having issues with a hydrostat trans in a G4200 Iused to own, changed oil to this....and after a few 10's of feet, issues went away, change oil and filter again to be sure all that old crap was out and havn't had an issue since, well, I sold that one a year or so ago, but it was working perfectly.
3,469
I use Rotella T6 15W-40 Fully Synthetic Oil in my B7100.
3,469
Lil Foot, does your oil come on a white bottle or a blue bottle ?
Seems like it used to be in a white bottle, but now I'm pretty sure it comes in blue….. I'd check, but it's 150 miles from here….
bamabota
L3200DT, LA524FL loader, 5' Land Pride bush hog
Jul 6, 2013
Oxford, AL
I use the Chevron Delo 15w 40, this is a full synthetic blend. I run this in my tractor as well as my F-250. I'm well pleased with the quality and several manufacturer's contract to them for their name brand oils. It comes in a blue bottle also!
Dan_R_42
Dec 1, 2010
447
Taunton, MA
The reason I was asking is I have have several friend's who use the white bottle and thought they had the Synthetic oil.
If it's the blue bottle it is the Shell Rotella T6 5W-40 Fully Synthetic
If it is the white bottle it's Shell Rotella T 15W-40 Triple Protection
(the 15W-40 is not a Synthetic oil, the T6 5W-40 is Synthetic)
There is also a gray/silver bottle that is Shell Rotella T5 which is a Synthetic Blend. It is available in 10W-30 and 10W-40
Leave it to Shell marketing to make it easy to mix up the similar blends. I use and have used the blue bottle for several years. Great stuff.
Hoping to save someone the aggravation of grabbing the wrong bottle of oil. :D
3,469
Thanks for the heads up, I'll have to verify.
gssixgun
L3600, FEL, SnoBlower, Box Blade, Rear Blade, Forks, Cultivator, Plow
Jan 5, 2013
258
47
Sandpoint ID
www.gemstarcustoms.com
You guys ever thought of using Premium Blue? I use it in my 6.7 Cummins.
http://www.valvoline.com/products/brands/valvoline/diesel-motor-oil/10
Yep that is what I use,,
Lubricants seem to be a huge "Hot Button" issue on all Tractor forums :p basically some swear by a brand and other swear at them..
Been a Valvoline and Castrol fan for way too long to change now, I would have felt comfortable with running either in my L3600, when I switched it over to "me" .. I lucked out the PO had kept pretty accurate time/weight markings on the tractor for maintenance but I had no idea of brands.. I made a decision to switch over everything to things that were available easily and locally.
The week I set aside to dump the fluids O'Rielly's happened to have the Valvoline on sale for a pretty darn good price so I bought enough for the next 3 oil changes... If the Castrol had been on sale I would have gone that way :)
Big Orange
L3650 GST LA650A FEL Howse 60 inch bush hog, Kubota L 321 60 inch snow blower
Jan 11, 2014
Ripley, Maine
I run Rotella 15w-40 in mine DONT use Travelers oil I just did mine with it and living in Maine it was -20 to - 10 for a week and it would not even move, I do not know what was in it before but I just wasted 7 gallons of Tractor supply oil. I put in Super UDT 2 and now have a new tractor. Loader is fast the GST has no hesitation this stuff is worth the money!! :D:D
gssixgun
Jan 5, 2013
258
47
Sandpoint ID
I tried to do the same, I really really wanted to try the SUDT 2, I searched within 100 miles of the house, that hit 3 Kubota Dealerships... They all used the NH brand.. I could only find 5 gallons of the SUDT 2 within the 100 miles..
Even though my Tractor doesn't require it I had heard stories like yours and wanted to give it a try at least..
I finally gave up :(
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,434
78
Rocky Face, Georgia
I use Amsoil 5w30 Heavy Duty Diesel in the engines and Amsoil Syn tractor trans/hyd fluid for the hyd system.
Don't waste your money on cheap hyd fluid.
