No drive in high Range
Iain
m1-55DT
Jan 2, 2014
Australia
I have a M1-55DT Synchro shuttle tractor ( M5950 variant?). It has no drive in high range, and low range feels that it may be in crawl. Dash light which I believe is Hydraulic oil is lit. Any ideas what could be wrong?
(My first post on any forum!)
Bulldog
M 9000 DTC, L 3000 DT
Mar 30, 2010
5,440
78
Rocky Face, Georgia
Have you serviced the transmission oil and filters?
If so, how many hrs on the oil?
How many hrs on the machine?
Iain
m1-55DT
Jan 2, 2014
Australia
Haven't serviced transmission oil or filters. Would that be a good place to start? Could a blocked filter cause there to be no drive in high range, but crawl range still work? I've checked that the transmission oil level - it's okay and the oil looks clean.
machine has done about 1700 hors.
many thanks
lsmurphy
B7001
Oct 19, 2012
1,197
Parrrottsville TN
many thanks
Yeah.....seriously time for a full service.
hodge
Nov 19, 2010
2,907
460
Love, VA
Welcome to the forum!
You should definitely service the transmission, and anything else that hasn't gotten attention. An ounce of prevention is better than a pound of cure!
navspecwar
B3300HST FEL, ATH72 Finish Mower, 5ft KKRear Blade,Piranha TB
Oct 5, 2013
101
Marion, Illinois
Never heard it put like that....I may have to use that line!!!
Bluegill
Jan 11, 2012
1,560
Success Missouri
Yep, it's way past time for a service!!! Get Kubota SUDT2 oil and new filter.
Might not be the problem though, maybe the lever is messed up and it's in
neutral instead of high?
Iain
m1-55DT
Jan 2, 2014
Australia
Thank you for your help. Turned out the lack of drive was caused by a clutch problem, unrelated to the warning light. The hydraulic system has now been serviced as well.
