Mountain Hill
L3800, LA524 FEL, Woods BSS 65 Box Scrapper, Woods RB 84 rear blade, trygg chain
Just purchased a Woods RB 84, 10 days ago, worked great for moving snow, from the two recent storms. However, yesterday while doing a little clean -up, the main bolt, (1" / 7") broke off, leaving the blade dangling from the three-point hitch.
Not a problem, ah yes the design problem with 'Woods RB84' ! The nut is welded on to the blade carriage, now with a broken off piece of 1" bolt stuck in it. This broken piece has now, to be extracted, at a machine shop. I had the problem of breaking bolts with other rear blades, but you simply replace the the nut,bolt , lock washer, etc. , and keep going. A trip to a Machine Shop, for what should be simple maintenance is very disappointing.
My other option is to have the nut cut off, then I can use nut and bolt assembly? Regardless I'm looking at $100-200 fix, for poor design.
