Hey all
I have not posted for sometime now. I had a thread going in regards to a b6000 that I cannot get started, which is currently in the shop getting an estimate for an engine rebuild however in the interim I picked up a basically brand new ( old 1992 model) B 6000 that appears to have a new loaded and tiller attached well. Paint, tires, hoses, all hardware appear to be new or redone. Turns out its a grey market tractor ( zen noh) with the rice patty tires. It has been running well and I have thoroughly enjoyed having a running tractor around the place for help. I have placed roughly 6 hours on it so far and just noticed it has begun to blow antifreeze out of the little tube from the collar of the radiator. Thanks to this site I know it's a thermo syphon style cooling system which requires the fluid to be above the top hose to function properly.
I checked this and it was a bit low, filled it but it still spews fluid. I have noticed the cap has a small section of rust in the center that the previous owner had covered with some form of metallic tape. The tape is no longer sticking so no longer blocking the hole. Would this cause a pressure issue that would keep the thermo syphon system from working properly and causing the fluid to overheat and drip out of the mentioned tube? Thanks for all of your time and insight. I will try a post some pictures soon, I know we all love pictures.
