kubota ballast box converted to quick hitch compatible
5,517
I hate you guys that can weld,,lol ,, Looks like it should work pretty well
gpreuss
Oct 9, 2011
1,166
Spokane, WA
GREAT JOB!! I like it....
kubotaguy
17
illinois
the "design" wasn't without some shortcomings. on the first pass with the components that hook up to the quick hitch, when I put about 200 pounds of sand and some steel weights in the box, I could not get the quick hitch low enough to allow it to be hooked up. :-( I have a friend who is an elevator technician and he gave me several (6 or 7) elevator counter weights each weighing about 100-110 pounds each. So my second "ECO" which is short for Engineering Change Order, was to bolt the two box beams to the bottom of the ballast box. With that, I got an unanticipated side benefit in that it pretty much makes the ballast box "tip over" proof. I've got a considerable amount of arthritis in my neck and it is hard to turn my head enough to get a good look at lining up the hitch with the ballast box. Over the years, I have tipped over the ballast box 2 or 3 times even with just 1/4 inch of misalignment. So.. with the box beams it just doesn't tip and if I am mis-aligned a bit it just scoots the ballast box along the ground without tipping it. The whole thing isn't perfect, but it gets the job done for me.
kubotaguy
17
illinois
my initial design also had a 2nd shortcoming. I originally put about 400 pounds of sand and 9 of the elevator weights into the ballast box. With the weight of the ballast box, sand, and elevator weights, I was at approx 1500 pounds of ballast. Twas a bit too much weight. I sprung the lower side plates (with the bushings) out a bit taking them out of alignment by about 10 degrees. So, I bent them back with my fine adjustment tool (an 8 pound sledge hammer) and then welded an extra 3/8 thick plate across the side plates.
That pretty much solved the problem. I'm a retired engineer from the big yellow and of course I have the utmost respect for a "true mechanical" design which would allow a finite element analysis of all structural components prior to fabricating any steel to begin with. But in a home shop, those kinds of computer tools aren't available to me. my point, "Structural engineering is a great asset"
Wildfire
Ah having things engineered takes all the fun out if it :D now you got to do things like us fellows, by the seat of your pants and hope it turns out right ;)
I had to do a few mods on my ballast box as well and I got 400 lbs in it.
Started out with this pos.
Ended up with this
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Noting the great job, I am wondering why not make your own box? You certainly have that capability. Since I'm a CE I make a little use of that background, but do a lot of seat of pants building of stuff that works quite well for me. One detail that you used I would not do. I find too often that the attachment that I want to pick up is not on level ground. Then that top hook does not engage. My top hook sits on the shelves seldom used. Instead I put a link between the top of the quick hitch and the tool. If I put several holes in that link it takes care of the poor setting until I can get to better ground. Also with just the arm hooks set you can play with the height to get things hooked at the top, but with the Quick hitch hook there that is more difficult than as I do it. And those half inch bolts never seem to get over-loaded on my larger tractors with larger attachments.. Click on thumbnail for larger photo.
Wildfire
Well that's a good question on the building of my own box and perhaps I should have but the box I had was given to me. It was built defective, as in one of the lower pin mounts weren't welded straight so once I got it I started getting a few ideas and went to work and did the mods on it. I've built other attachments for it as well plus I use the QA with our chipper and it's easy to attach anything to it.
I have no issues using the QA with the top hook. Actually if I had to remove the top hook to use it I probably wouldn't use the QA at all. Kind of defeats the purpose of it in my mind if you have to start lining up a pin instead of a hook. :confused: but what ever works is fine by me :)
Putting an attachment on our QA is just a matter of backing up to the implement and raising the 3pt hitch and it's hooked up. Nothing easier than that. Once the height is set for the QA top hook I've never needed to move it. Not sure what you mean by " I'm a CE"? Civil engineer?
Kennyd4110
Vendor Member
Sep 7, 2013
1,515
901
Westminster, MD
www.boltonhooks.com
Great job! It's crazy that Kubota will not follow the ASAE Category 1 Standard S278.6 for quick-attach hitches when they build these boxes. You just shouldn't have to cut and weld a brand new attachment for your tractor.
5,517
Paul I know those have got to be old pictures, cause by now everything your way is WHITE,,,,lol
Wildfire
So true. Its kind of crazy but it is what it is. To tell the truth I enjoyed doing that little project :D
That one was taken this past spring. This one I snapped just for you a few minutes ago. The only time I've seen snow was on CNN. We had a few flurries and they are calling for a little tomorrow but I'm not expecting much.
5,517
Gee Im sorry Bud, Im sure we could get together and send you some of ours,,,:D And ya know every time I see that thing, I think about those handy dandy drink holders you put there:rolleyes:
cerlawson
Feb 24, 2011
1,067
PORTAGE, WI
Wildfire:
Nice photos. In reply to question, yes I am a civil engineer, age 85 now. Still get out there in the mud now and then, self employed.
As to not using the top hook for the QH, several of the attachments I have used, usually for a larger tractor than the BX, have the pin there set back inside a support, so that there is no way that the top QH hook will engage with a simple raising of the 3 pt..
Wildfire
No. Please. I don't want snow. Not at least for this winter:eek: kind of getting used to seeing the ground brown and not white. Hey that drink holder still comes in handy lol.
Wildfire:
Well sir you have my respect. I got a long time friend who was a civil engineer. He's now retired but he hardly knew what a tire valve was so your leap years ahead of him. To be fair to him he's always relied on me for mechanical issues.
I think it's only recently that implement manufactures are building their products that work and fit well on the new QA systems but when it comes to the sub compact machines it's hit and miss with them.
I to have to make sure that where ever I drop an implement I need to make sure the implement is level or it's a devil of a time to reconnect to the QA so your idea would be perfect in those none level cases.
Thanks for posting. Enjoyed seeing it. :)
bandaidmd
B2620 w/LA364 FEL ,BH65, ssqa , 1982 B8200E w/BF300FEL
May 19, 2013
603
Middle of DELMARVA
My hydraulic top link makes the already easy job of picking up a implement with the qh even easier.
And Mr. Paul, did I miss your post about adding forks to the bx or did you slip that one in there. lol
Wildfire
I think I've posted on them before. Those buggers cost me as much as I paid for the ones on the Grand L :mad: I'd like to know who decides how much they should cost. Anyway I bought them and use them. Glad I got them. :)
mark8235
BX 2360, FEL, 54" MMM w/mulch, Ballast Box
Nov 20, 2012
9
Eastern Shore, MD
I just made mods to my Ballast box and thought I would share the pictures. The welder charged me $10.00 for material and I gave the welder $20.00! That's it and it works great. I primed with Rustoleum and then used Kubota spray match the color.
Pix 1 - a look at the original placement of the ears from the factory.
Pix 2 - Welder added a 1/2 inch piece of steel and from center hole of original to center hole of new add on is 4 inches.
Pix 3 - view from other side
Pix 4 - View head on
5 - Just to show what I used on the top pin.
