I've been getting all service up to date on a L3400DT (gears). It's an 06 and had 119 hours with no oil or filter changes when I got it. Thats all taken care of.
I got around to the clutch adjustment as described in the owners manual. It's a 2 part adjustment since it's 4 wheel drive. First adjust peddle play. Then make an adjustment to 3 places on the flywheel, accessible on the flywheel housing.
The problem is that the cover on the flywheel housing is right behind the loader mount. There is only a half inch or so of room. So here are my questions:
1. Does anyone have any advice or tricks to make this adjustment with the loader on? I guess it would do me good to remove it if I have to.
2. How important is this adjustment? I had some gear grinding but there was a lot of slop in the peddle. Making that adjustment helped a lot. If I am patient and give it 3 seconds after pressing the peddle there is minimal gear noise, yet some.
3. I'm wondering if this secondary adjustment is out of tolerance would it make the gears more prone to slip rather than grind?
I welcome any advice / coments. Some of you geniuses have some good ideas on this I'm sure. This is my first request for help. Hopefully I can be on the helping side soon.
Thanks,
Tom, the guy with the valve job
Thanks,
