brockkrak,is it even possable to turn the injector pump up on a B6200 and if so how
Good luck finding someone to give you the answer to that one. I can explain how if you like but it depends on what you are expecting. You may get 1 or 2 more hp out of it but that will come with clouds of black soot. The small displacement engines such as yours have so little room to work with. Generally they are maxed from the factory.is it even possable to turn the injector pump up on a B6200 and if so how
Maye this is what he is looking for...HA!You can have the pump "rodded" up built to deliver more fuel and the injectors tweaked at a diesel shop to handle the extra squirt, you could crank on the fuel limiter screw, and re-adjust the throttle stop, I suppose.
I just don't know what you would do with 310HP on your B6200!
:d :d :d :d :d :d :d :di just don't know what you would do with 310hp on your b6200!
Keep us updated if you actually get it done.Ive seriously thought about how hard it would be to mount up a turbo on one of these. Im really big in high performance diesels (pickups). Not looking for a dragster but to put out a little more ummphh. Ive been bored over the winter and am mocking up a turbo off a small yanmar gernerator.
Promise that you will let us know about your failures as well as your success's.While I have this thing apart I might even be bored enough to do a little porting to the little thing!
One word fabrication! I have tons of spare parts from building trucks laying around. I will share my successes and losses. Hardest part is an oil supply to the turbo. Piping and hood fab not to hard.Promise that you will let us know about your failures as well as your success's.
I don't know about your engine compartment but mine doesn't even have enough room to take a deep breath. You may be looking at fabricating an entire new engine cover, at the least.
Do you have a big enough drill bit to punch a hole in you bank account to do this procedure?
Scott
I can tell the wheels in your head have been spinning.One word fabrication! I have tons of spare parts from building trucks laying around. I will share my successes and losses. Hardest part is an oil supply to the turbo. Piping and hood fab not to hard.
